Question about Acer Aspire 5100-3357 Notebook
Using battery charger with 3.42A vs 4.74A for lap top
I have extra battery charger for acer aspire 5100 (3.42A) .can i use this charger for acer aspire 5315 (4.74A) that enough amps to charge the 5315? Might damage it?
  • big6usaf Mar 03, 2009
    Thanks for responding oblivion2K..
  • faithmomof3 Mar 20, 2009
    But what if I try to use the 4.74A in my acer aspire that says 3.42A? Will this cause damage?
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
Posted on Aug 08, 2012
  • 150 Answers
Check the amperage on the ACDC adapter block for both of them.
Posted on Mar 02, 2009
  • Kurtis Stalnaker
    Kurtis Stalnaker Mar 02, 2009
    My apologies, I didn't read the question fully.
    No, if you attempt to use the weaker adapter to charge the device, it will fry the adapter, that difference is much too large to work.
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
Battery indicator keep blinking
Try updating the BIOS.
The link for the latest BIOS is given below 5100&OS=V10&LC=en&BC=Acer&SC=PA_7
To flash BIOS in Windows mode, please extract and run the flash32.exe.
Jun 09, 2010 | Acer Aspire 5100 Notebook
Laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
May 03, 2010 | Acer Aspire 5735 Notebook
Acer aspire 5100 BL51 windows 7 wireless driver
You will have to navigate this site; enter 'notebook', 'Aspire', and scroll to 5100; after that, you will have to choose 32 bit or 64 bit. That being said, Acer does not support Windows 7 yet-you can try the Vista drivers; more often than not they will work. One note-I cannot tell just from the info you supplied whether you have the Atheros or Broadcom chip-You should be able to determine that in Device Manager.
Mar 10, 2010 | Acer Aspire 5100-5022 Notebook
When i connect lap top to tv all it shows is desktop how do i get it working
can you clear what you want to say , When you connect you lap to TV it shows only desktop Right? and you can not do on that screen .
If the problem is same as I say. You may have to attache extra key board and mouse to use your TV desktop
Aug 23, 2009 | Acer Aspire 5100 Notebook
Screen black wont boot up
If it is new and under warranty. Use its warranty.
Apr 14, 2009 | Acer Aspire 5100 Notebook
Concerning the battery chargers for 5100 and 5315...I had the Amps backwards...5100 is 4.74A and the 5315 is the question now is: can i use the 4.74A charger to charge the 5315 lap top (which is...
Hi there.
You must only use power supplies which are specific to that particular laptop, even if you have a power supply of the same voltage but the amps are different it may power the machine but in my experience they have blown the PB (power board) which has resulted in no charge at all right down to the motherboard itself being blown.
I suggest you use the power supply specific to that laptop.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
Acer aspire 5100
look on the front of the lap top for a button fo rthe wireless network and turn it on
Jan 13, 2008 | Acer Aspire 5100 Notebook
Acer Vista Lap Top Won't Recognize USB Flash Drives
If Acer screwed up fixing your problem the first time (and it's evident that they did) they are obligated to fix it a second time, and if they cant, they are obligated to replace your laptop.
Dec 31, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Red Battery Light
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Dec 10, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-3357 Notebook Logo
642 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
