Question about Pioneer CDJ-500II CD Player
Internal fuse blows as soon as transformer switched on.
  • Scott Frye
    Scott Frye May 11, 2010
    HI...
    Does the fuse blow if you disconnect all the cables going to other assemblies..like the CD drive, front panel etc?
    You might be able to narrow down the trouble by taking things ":out of the circuit"
    There are some folks online who sell replacement parts for that player
  • Rob
    Rob May 11, 2010
    Is there an interal power supply board that converts 120VAC to something Like 12-16VDC in this thing... And then the 12VDC is tapped onto a mainboard?
    If so, check the power supply board for bad components, and check the reverse-polarity diode on the mainboard, if any.
  • 4 Answers
If the player have been dropped once, it could be a broken circuit board as the transformer sits in between two boards and the mounts for it will bend easily. Or the voltage selector switch on the back are in the wrong position.
Posted on Apr 07, 2009
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
Apr 04, 2017 | Heating & Cooling
My Panasonic sc-VKX60 doesn't switch on. What I should check.
First fuses in the plug then internal ones. Then investigate the power supply section. Starting with the power switch, then transformer etc.
If you replace an internal fuse and it blows again, suspect an overload somewhere.
Jun 27, 2015 | Panasonic Audio Players & Recorders
I have a speed queen sc35md2yu40001washer that keeps blowing the 2amp fuse as soon as I switch on the breaker it is the fuse where the incoming power goes through before it goes to the transformer
Good job tracing the location of the fuses. Now, logically, the transformer is the next thing to check. When power is turned off at the house breaker, remove one of the wires on the output side of the transformer and see what happens when you turn the power back on. If the fuse blows, the transformer is shot and needs to be replaced. If not, go to the next device on the circuit, etc...
Jan 16, 2013 | Washing Machines
MY CEBORA S21 MIG 190L KEEPS BLOWING FUSE,I HAVE REPLACED TORCH AND LEAD ETC CAN YOU HELP
Does it blow when the trigger is pressed or as soon as the mains power is applied??? If it blows when first turned on it could be the cooling fan or the main transformer or auxillary transformer if it has one. If it blows when triggered it could be the pcb or the wire feed motor ,diode bank or main transformer .
Sep 28, 2009 | Welding Tools
No power and no clock or light
Internal fuse, Dangerous for the untrained. Have to find the cause for the fuse blowing. Eric
Aug 08, 2009 | Microwave Ovens
My Behringer ADA8000 Ultragain Pro-8 stopped working all together
Hi. I have an 2 ADA 8000 and one went down with the same fault after 7 years.
Firstly, there is a slow blow fuse in the back above where the kettle lead goes in. CHECK THIS FIRST!
If, like me, you change it and it blows again, change it a second time and it maeks a "crackling noise internally. There is a problem with the internal transformer.
From a lot of talking and searching, I've found out what you need to do. Either yourself or and electronics expert needs to do this.
First of all, you need to order a NEW transformer. You need the specific one from Behringer.. I am in the UK and obtained it from EMS. Their number is 01702 613 172. While waiting for this to be delivered, you need to check the power regulator and the 100Nf capp and the 10Nf caps as these can go faulty and cause the transformer to "over work", meaning that as soon as you put in the new transformer, it could go again pretty soon.
These caps I'm told are generic and do not need to be obtained from Behringer. THE TRANSFORMER DOES.
I Hope this helps you all out as I could not find this information online, this is from genuine experience, from people "in the know". Please spread this info about to help others like us who are stuck in a tight place.
Apr 07, 2009 | Behringer Ada8000 Ultragain Pro 8 Ch...
Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Nov 19, 2007 | Microwave Ovens
Wont turn on
Nov 11, 2007 | Frigidaire GLMB209D Microwave Oven
Sunbeam Microwave stopped working suddenly
Here's the overview on fuse blows: If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, troubleshooting info, door switch info, etc. at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 30, 2007 | Sunbeam SBM6500W Microwave Oven
Unit shuts off (JVM1340WW002) and blows fuses
Generally speaking, if the high voltage capacitor is shorted, the fuse will blow as soon as you hit the START pad. When the HV cap fails, I've never seen one do anything but short. If it's a few seconds or so into cooking, it's usually the high-voltage transformer. There may or may not be a burning smell. The cooling fan often will dissipate the smell. What can happen to the transformer is an expansion of the windings to the point where a couple of hot spots eventually make bare spots which touch, then the short causes the fuse to blow. When it cools, they aren't shorting anymore. It's possible it's the mag or something else, but not too likely. You can (carefully!) disconnect the primary leads from the HV transformer then run the oven, making sure the wires are free and clear. If the fuse blows, the problem is in the low-voltage side. If it doesn't the trouble is in the HV side. If you broke a seal (tamper tag) or left any other evidence that you were inside the microwave, your warranty will be voided. Some parts may be covered, but the labor warranty usually expires sooner. Be careful.
Nov 06, 2006 | GE JVM1440 Microwave Oven
Pioneer CDJ-500II CD Player Logo
135 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
