Question about Frigidaire FEB27S5A Electric Single Oven
I have a Figidaire (Gallery) built in double oven. I tried to use the Clean button. It's been running for2 days. I can't stoped. The door is locked and the vent is on. I don't think it's cleaning. If a push the Cancel button it starts beeping every couple of mintes with an F8 code. Thanks R Cook
    Sergeant:
    Novelist:
  • 277 Answers
In order to fix the oven the door latch assembly has to be replaced.of the oven is in cabinet then the the oven has to be removed from the cabinet because the part is located on the back of the oven.
The part number for the door latch assembly is AP2128406 .
and the pictures and diagrams are given in the link above
The door latch assembly is shown on the break down diagram with the references number 89.
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Posted on Mar 02, 2009
  • 1,031 Answers
F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking Self-Clean mode.which can cause a failure within Electronic Range Control (ERC) effecting temp processing circuits
    Genius:
  • 1,550 Answers
In your oven the door latch assembly has to be replaced.
You cant clean unless the door latch is replaced .
You can get from the link below
Door latch assembly
Hope this helps .
    Scholar:
  • 150 Answers
F8 is an oven door lock failure, either it is stuck closed and won't unlock or the door thinks it is open. Whatever it may be, it is not good that it has been running for two days. Unplug the oven if you are able to get back to the cord. Leave it unplugged for 30 minutes, and then plug it back in and see if it functions correctly and you are able to open and close the door without any errors.
  • 13,433 Answers
Unplug it for a while, plug it back in see if it unlocks, try pressing the cleaning button again and see if it unlocks.
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
LG double oven shows f9 code in both ovens
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Frigidaire FEB27S5A Electric Single Oven Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
