Question about Konami Dance Dance Revolution SuperNOVA 2
Black screen When you insert the disc in, there is a black screen and no images or music are showing...
  • 81 Answers
You can have problems with your disk if it is pirated
Posted on Mar 04, 2009
We hooked up a jvs dvd player to our curtismathes tv now when we put a movie in it has a split screen and only shows in black and white
Check the format of recording on the disc you inserted in now. Check with an other known disc, and see the result. If both shows the same fault, check the picture setting by entering DVD menu.
Dec 10, 2013 | Curtis-Mathis CM32010 TV
Bootmngr missing
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 23, 2012 | Acer Aspire X1200 PC Desktop
Placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
I have the Lumix Panasonic DMC-F2 and I uploaded pictures on my computer and now some of them won't show up on the camera. It only show's a black screen. But all the pictures still show up on my...
Have you rotated or manipulated the images in anyway? If so that is what your problem is. If not save the images to your hard drive and burn them to disc and format your memory card.
Nov 11, 2010 | Cameras
White line appears in the middle of the screen
please describe the issue better cause it doesn't make sense..are you saying that your screen background is black no matter of the picture you choose??or that the image of the monitor is just showing a black screen??in the case I sescribed ..if the operation system seams to work but you can not insert any pictures anymore on wallpaper and it is black ..and a genuine advantage program is inserted a banner in the tray system ..(right ) ..this is a case that yous windows is not genuine and the warrning was placed after you check it on a installation ...to get rid of it ...just make a search in the start for a file named..WgaLogon.dll ..and after you lcate it ...rename in by changing a letter in th emiddle (ex: WgaLogTon)..and restart the computer ..after this the functions will be right back ..insert another walpaper and go on ..
If you are talking about the image being just a white line in the middle and the rest is black like it is shut down..than the issue is caused by a condenser burned on the image board..you should have it checked and changed..
Jun 01, 2010 | Dell E551 15" CRT Monitor
Not able to burn CD
If you have a desktop PC, try to replace your CD Writer / Burner or return it for replacement if there is still a warranty.
May 27, 2009 | Microsoft Windows XP Home Edition for PC
New disks won't work, wii doesn't read
If Wii gives Disc Read Error, first step you need to check is totry another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 23, 2008 | Nintendo Wii Console
Carrozzeria avic drv 250 problem
check out bootdisc.ru
I have the drv-250 and download the disk from here....works perfectly now
Jun 21, 2008 | Pioneer AVIC-N2 Car DVD Player
Panasonic CQ-VD5505W dbl-Din dvd 7'' touch screen CAR AUDIO
i got the same problem and i ground the green/white to the case of the unit. do i have to ground it to the chassis?
Dec 04, 2007 | Panasonic CQ-Vd7001U
Portable dvd
err disc, what does it mean? My player suddenly displayed this error message, how do i solve it?
Aug 18, 2007 | NextBase SDV-17 Portable DVD Player
Konami Dance Dance Revolution SuperNOVA 2 Logo
130 people viewed this question
Top Konami Video Game Consoles & Games Experts
Gabriel Olusegun...
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
