Question about Cameras
When trying to download of a memory card,camera displays "comminication error"
  • texasropeman Mar 02, 2009
    Thank You..Will try
    Genius:
  • 2,035 Answers
Please check the usb cable connected to the computer , is it possible to transfer the pictures only from the camera memory ,if yes then it is the problem with memory card ,but if your not able to transfer photos from either
mm card or camera memory then try to reinstall the software on the computer and check ,before doing that please try in different usb ports and check if your getting the same error .....
Good luck...
Posted on Mar 02, 2009
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
Better change the memory card, and use another data cable for that.
  • 10,594 Answers
If you mean that when camera connected with PC to download pictures, camera shows communication error then please check usb cable and use another usb port in PC.
    Brigadier General:
  • 5,158 Answers
The card may be set to not allow reading... look for a small switch on the card
  • 13,433 Answers
Try the memory card in your computer or in another camerat osee i the card works fine.
    Genius:
  • 1,550 Answers
Format the memory card and connect once again .
  • Cameras Master
  • 19,396 Answers
Try accessing the memory card with a card reader, try also a different usb slot.
  • Ginko
    Ginko Mar 02, 2009
    Check first that you have fresh alkaline battery inside the camera, if batteries have not enough charge, then you can get Communication Error because of drained batteries.
    Try also unplugging computer power cord for ten minutes. If the computer is a notebook also remove the computer battery.
    This will drain power from computer, and can fix communication error related to USB port problems.
    Test also a different usb port.
    And test a replacement usb cable, a faulty usb cable can give you communication error.
    If all the above does not work, then you probably have a problem with your Windows installation.
    Try doing system restore to a recent date before you started having the problem.
    You find system restore on
    Start button>>Programs>>Accessories>>System tools>>System restore.
    Chose the most recent date before you had the problem.
Memory card error
This seems to be a known issue with the Canon camera's to display Memory card error.
Give this a try
1. Remove the card from camera and wait for sometime ( 1-2 minute ) and re-inserting the card.
2. If this does not work, you need a card reader to read/view images on your PC ( since you are not able to access the card in your camera )
3. If you are not able to access/view the images from Card, click on the link below to recover the images from card - Recover images
When you open the webpage, click on the Download Now option to download the software ( it is free )
4. Try this fix to resolve the issue, Sometimes it takes long time for the camera to load the images and it results in memory card error - Click on the link to download the fix - Firmware Update
5. Try using a SD card with less memory like 1 GB card or max 2 GB for better access of card in camera.
Hope this is helpful.
Nov 05, 2010 | Canon PowerShot S3 IS Digital Camera
I connected my cable to transfer pictures from my canon 100 ixus but it showed connection error. What does it means?
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd780_is#ServiceAndSupport
Troubleshooting the camera displaying Communication Error when connected to the computer via USB. If the camera displays "Communication Error," when trying to download images the main cause for this error is that there are more than 1000 images stored on the memory card. It is recommended if there are more than 1000 images on the memory card, that you use a card reader to acquire the images, or to delete images off of the memory so that there are less than 1000 images to download from the memory card.
If this is not the case, there are not 1000 or more images on the memory card, try reconnecting the camera to abnother port on the computer, try another cable or another computer. This error can also display when connecting to a direct print printer. Please check with the printer manufacturer for more information on this error.
Jul 31, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
I carent get a memory card to work at all. Tried a 2gb and it comes up with ERROR and askes if i wanna format the card, so I formated the card, and it went to picture display screen, took a photo and it...
these cards is too much for the cam can hold and would cause errors just like u said try 512mb memory card or even less should work good and then clean it up by downloading all on ur pc and re use it i use 128mb even for mine lol,hope that helped ty
Oct 30, 2009 | Vivitar ViviCam 3750 Digital Camera
Camera wont transfer images to laptop
Sep 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card error
When purchasing memory cards for cameras, you must specify HI SPEED. Low speed cards error out all the time.
Is this the original that came with the camera?
Jul 21, 2008 | Canon PowerShot SD600 Digital Camera
Camera display shows "memory card error".
I would give this software a try:
http://www.download.com/VirtualLab-Data-Recovery/3000-2248_4-10610841.html?cdlPid=10801131
and be more vigilant about backing up your pictures. Flash memory can corrupt at any time. Good Luck.
May 05, 2008 | Canon PowerShot A520 Digital Camera
Canon powershot A70 digital camera
The memory card may be failing. Recommend trying a different memory card to verify. Do you still have the original low value card that came with the camera? If so, try that one to see if you still have the problem. If that one checks fine, then you know it's time for a new card.
Feb 14, 2008 | Canon PowerShot A70 Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Memory card error
The problem seems to be that the card has been formatted incorrectly (probably by your computer, if you used it in a card reader?). Unfortunately the camera can't reformat it itself, and default computer formatting is incompatible. You'll want to download the program Lowlevelformat.exe from this website--http://olypan.quotaless.com/forum/viewtopic.php?t=8, install it, reformat your memory card with it, and the camera will be happy with it again.
Oct 01, 2006 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
