Question about GE Televison & Video
How can I record TV show? What buttons do I push?
I have my vcr hooked up to an old Magnavox. at first when I pushed the record it lit up but didnt record. now it will not even light up. how do i record off the TV? power is on and vcr will play tapes. thanks
    Novelist:
    Scholar:
  • 95 Answers
Well my friend, you have many variables that can cause this issue. Here is a list.
  1. Check the tape record prevention tab to see if it is not missing that will cause it NOT to let you record. Put a piece of scotch tape over it if you wish to use that tape.
  2. Make sure it plays back. If it does not play back, it might not record.
  3. Turn the TV on, look for Audio and "Video Out" and connect it to the INPUT Video Out and Audio Out. You cannot use the TV to power the VCR. The power plug must be connected to the wall outlet.
One of these should solve your issue.
E
Posted on Mar 02, 2009
The VCR is playing and functioning, but the picture won't show up on the TV. I have all the channels set and it should be working, but the TV is the black and white static. Could it need dusted? It hasn't...
make sure the tv vcr button on the vcr is selected to vcr and that you have the tv on channel 3 or 4. try pushing the tv vcr button a few times back and forth on channel 3 then on 4. if that doesnt work try hooking the vcr up to the tv with the rca jacks. they will be yellow, white and red or maybe only two from the vcr yellow and white. hook them up the the correct input on the tv and change the input on the tv. if that doesnt work, your vcr may be done.
Dec 24, 2010 | RCA VR557 VHS VCR
My vcr wont record when programed but will if you just push the record button
When you set the timer see if PDC appears. If it does switch it to off and try setting a record. PDC sometimes doesn't work. And the recorder will sit there waiting for the signal to tell it when to start recording. Which never comes! However you will have to set the time to adjust for it not recording late running TV shows. For example a show to start at 8pm and finish at 8.30pm, will need to be set at 7.59 till 8.35pm. Or you could miss the start or end! Wheras PDC would get it all even if it started at 8.05!
Nov 22, 2010 | Sharp VC-H982U VHS VCR
Can;t record on VCR since Comcast went Digital
I have Dish Network and a DVR and I do not know what I would do without it. I can record 2 shows at once and watch to 2 recorded programs while recording two shows. But getting to your problem... It sounds like the vcr cannot process the digital signal. You could try hooking up the vcr to the rca inputs from the cable box but you will only be able to record whatever channel the cable box is on. Any way you hook them up the programming of the vcr to change channels at different times for different programs probably won't work now. It sounds like Direct TV with two DVRs will solve your recording needs.
Sep 13, 2009 | Toshiba Televison & Video
I have a sansui vhf6010 vcr. i need to hook it up to my cable dvr to copy a recording. how do i do this? thanks!
connect the cable from the tv to the "IN" of the vcr. then connect the "OUT" of the vcr to the tv. play the program on your tv and push record on the vcr. you have to watch what you're recording, but at least it will record.
Dec 30, 2008 | Sansui VHF6010 VHS VCR
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
VCR RECORDING
make sure it has a signal going into it and that you can see it on your TV (put the VCR in vcr mode by pushing the vcr/tv button) , put in a tape and hit the record button. (some vcrs you push the record and play buttons at the same time)
Dec 31, 2007 | Televison & Video
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
right.
Nov 11, 2007 | RCA VR355 VHS VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Can't see menu to programme VCR
Try unpluging the unit from the wall for about 5 minutes then plug back in and turn it on,this will reset the brain and go back to normal.
Oct 05, 2006 | JVC HR-A592U S-VHS VCR
Televison & Video Logo
174 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
