SOURCE: 1999 Alero
check the entire engine freeze plugs hoses radiator . check engine oil .if look like milk shake you got a blown head gasket. if it dont burn oil dont smoke . fix the leak . if it got 150000 or more . cost to much to fix buy another engine.
SOURCE: broken a/c compressor
it depends what you want to do. you can take the compressor right out and run a smaller belt.,if it will allow that,or replace it if you want air conditioning.
SOURCE: How do you change a serpentine belt on a 2003 Oldsmobile Alero?
Brute force - you have to pry up the tensioner pulley. The way we did it was put the belt over the alternator and A/C compressor, and get it back in place around the main bearing pulley. Then we took a bar and forced up the tensioner and slid the belt over the main bearing pulley. Voila . . .
SOURCE: Replacing a serpentine belt on a 2000 Alero -
its not a hard job to do you need a wrench to rotate the tensioner bolt.a socket and breaker bar wont fit.
SOURCE: I have a olds alero. I just replaced the pulley
seems like the pressure line to the rack&pinion is plugged.open the line at the rack see if fluid flows if not replace line if fluid flows then replace the rack.
