Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
When i start my washer water does not come out yet it spins
  • 323 Answers
Make sure that both faucets the lines are connected to in the rear are TURNED ON, and that the right ones are selected. (Left is usually hot, right is cold.)
Then make sure they are properly hooked to the right lines on the back of the washer.
Finally, set the washer for a brief cycle with COLD water only.
Posted on May 12, 2009
What size water line do I run for my kenmore all freezer ice maker
If it's a new in-wall run to it, standard 1/2" is fine. From the wall to the freezer you can do 3/8" or 1/2"
An ice maker doesn't use a lot of water so you can consider it a low demand system. If you're connecting from wall to freezer most hardware stores have premade hoses; just like the water hoses for a washer or a toilet.
Jan 24, 2015 | Kenmore 18.6 cu. ft. Built-In All-Freezer...
Water leaks when machine begin to spin
check the seal and tank for cracks
Sep 02, 2013 | Freezers
I am trying to install a new water filter and water wont stop gushing
There is an oring ( black washer that looks like a black band ) that is not in place . You must have that to keep it from leaking.
Mar 01, 2013 | GE Smartwater Refrigerator Ice Maker...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Your Question hi i have a caravell 306995 freezer and the fan on bottom stopped working. i try to help the blade to spin but it'll spin for a minute then stop. it looks like it wants to spin but itll...
You can try and oil it if it has oilers on it...... or try and spray some WD40 right where the shaft comes out of the motor....If you can't get the motor to start then you may have to unload the freezer if you can't find a new motor to replace the bad one. good luck.....
Apr 19, 2011 | Freezers
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
I got a commercial frontload coin op washer for dirt cheap sold as scrap, but brand new. There was a manilla envelope without any paper work taped to the inside of the machine. The number on this envelope...
The problem was never solved. I never got to chat with anyone about anything at all, and I dont have a ******* freezer. If I was able to chat with someone I would have been able to get the proper model number from my washing machine.
Cancel my subscription and I want a refund in full. Dont send me any more emails, unless it confirms my subscription is canceled. I will not use your service. Your website is to complicated and is designed to rip people off.
Feb 15, 2010 | Frigidaire 17.8 cu. ft. / 504 liter...
Paddle won't spin
I have a White Moutain freezer motor that is two years old and had the same problem as yours. During my last batch of ice cream the motor was spinning but the beater wasn't turning. I removed the motor and the square drive was spinning but I could stop it with my finger, there was no power like a gear or clutch was shot. I called the 1-800 number on the motor and they said they would send me a new motor. I didn't need to show a receipt or anything. All they wanted me to do was return the broken motor and they even supplied paid postage. I recomend you call them and ask for a new motor.
May 26, 2009 | White Mountain Freezer F69206-X 6 quart...
Freezers Logo
47 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
