Question about HP iPAQ HX2490 Pocket PC
Screen is frozen at the ''align screen''. The battery is fully charged. I have used the reset button many times without results. I have removed the battery and then replaced it with no change in the frozen screen.
  • Anonymous Mar 26, 2009
    me too
  • macmaster May 02, 2009
    on trying to realign screen there is no prompt coming up to alert you that the screen is aligned. Alignment screen just appears to be going in a loop.
    tryed hard & soft resets but problem still exits.
  • 4 Answers
I posted a solution for this problem just using your finger to align at first then use the stylus, at any point where target doesn't respond use ur finger.
Posted on May 03, 2009
Says Do not disconnect on screen and is frozen there
If the Player is frozen while connected to the Computer, then reset the Player by pressing the RESET button without disconnecting from the Computer. Once the Walkman player is reset, then remove it from the Computer. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed.
After charging the Walkman Player, you can use it. If the issue persists, FORMAT the Player to resolve the issue.
To format the player, select the FORMAT option from the Common Settings menu of the Player.
Thanks for contacting FixYa.
May 07, 2011 | Sony NWZ-E436F MP3 Player
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Sat nav won't reset. have tried the re-set button. Screen has frozen
If the reset button of your device is not resetting the device and it is still on the frozen screen. Just turn to the back of the device, unlock the battery from the device and remove it. Then you allow the device rest for about 5 minutes then you fix it back in. Plug the device for about 2 hours and power it on. It should work fine after this. Be sure not to turn on too many applications on the device at the same time time, because that could result in the device being frozen again.
You can as well update the software of the device by charging it for about 2 hours, then you connect it to the computer that has its software. That will show if there are recent updates for the device, then you update the software with the latest version. that should take a little while to update. Then install your maps on it, safely disconnect the device from the computer and turn it on. That can also help you solve the problem.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | SNK RAC SAT NAV 200 GPS Receiver
My screen is frozen even after trying reset it. What should I do? The battery is fully charged.
hello , since u have tried reseting it , u have to hard rest the devive , follow the instructions below,,
Hard Reset (PRS-600/900)
WARNING: A HARD RESET WILL ERASE ALL TRANSFERRED CONTENT ON THE READER. IT WILL NOT ERASE THE BUILT-IN DICTIONARY.
1. Power off the Reader.
2. On the bottom edge of the Reader, using the stylus, press the RESET button.
3. Turn on the Reader.
4. While the screen displays Opening book... , simultaneously press and hold down the Page Turn button and the VOL + button until the Reset All screen is displayed.
NOTE: If Opening book... does not display on the screen, charge the Reader's battery for several hours before attempting the reset process again. 5. Touch YES to reset the Reader.
,,,regards ..i hope this was helpfull
Dec 04, 2010 | Sony Reader Touch PRS-600
Non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
May 29, 2010 | Amazon Kindle Wireless Reading Device
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Screen frozen on slide to power off
Turn iPod touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Nov 18, 2009 | Apple iPod touch
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My fully charge sony media player NWZ-E435F will not turn on
Hey...Just remove the Battery for 2mins, reload and Power ON again...It may work
-sai
May 21, 2009 | Sony Walkman NWZ-B135 MP3 Player
My O2 xda II is frozen
the given informtion is not enough to solve this problem.
Jan 02, 2007 | O2 Xda IIs Pocket PC
HP iPAQ HX2490 Pocket PC Logo
209 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
