Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I am trying to fax and the rollers seem to be not allowing the paper to feed through smoothly.
  • kmcquade Mar 02, 2009
    The model is the Canon Super G3 Faxphone L80 and the rollers have been cleaned and the thickness of the paper is just regular paper and the problem is still persisting.
    Sergeant:
    Novelist:
  • 277 Answers
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Mar 02, 2009
    Brigadier General:
  • 5,158 Answers
Look in your manual ... there is only certain thickness of paper you can use on that... you may have exceeded it.
  • Canon Master
  • 13,433 Answers
Clean the printer and its rollers and try again
  • Ekse Mar 02, 2009
    Could you tell us the brand and model of your device, that would help alot in helping you.
  • Ekse Mar 02, 2009
    try to
    Hope you can see the text, its quite small.
Paper feeder does not feed papers properly.
Remove the paper tray and check the pickup rollers that are located on the underside of the fax, just above where the paper would sit when the tray is installed. If they are smooth this is a sign that they are worn out. Newer pickup rollers are very grippy. A quick temporary fix would be just wiping any grime or dust off with a damp cloth.
May 20, 2011 | Samsung Office Equipment & Supplies
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Feb 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Adf sporadically pulls fax/ copy through top
Yes,but the most imported part for dubble feeding is the sepatation pad,this white pad is on the lower part of the docfeeder and work with the feed rollers,fist make sure that pad is clean before you replace the rollers,and then replace the pad.
Jun 17, 2009 | Canon PC-1080F Plain Paper Laser Fax
Paper will not feed through - Samsung SF-4500c FAX
try isopropyl alcohol it may work for awhile depending on how smooth the tires are, you can replace them:
try this site
precisionroller.com
Aug 12, 2008 | Samsung SF-4500 Plain Paper Thermal Fax
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Brother FAX-575 Cannot receive
Check your feed rollers that feed the blank paper into the machine. Take a flashlight and watch the rollers to make sure the rollers are spinning and trying to feed the paper.
If the rollers spin, and it doesn't pull the paper in, then your feed rollers are either worn or dirty. I would try cleaning the rollers if they are slipping on the paper. My suggestion would if you can find this cleaner called GOO GONE. This is a bio degradeable product that won't dry out the rollers and it will clean them.
Put some goo gone on a paper towel, and see if you can clean the rollers.
If you still have other questions, feel free to post them here.
Good luck.
Hope this helps.
Mac.
Please remember to post a feedback and or a rating if I have helped with your question.
Feb 12, 2008 | Brother FAX-575 Plain Paper Thermal
Loading paper in fax machine
Relax ti mal- the rollers are not picking up the paper because they are dirty or worn out.
Try this clean the rollers with alcohol and try, are the rollers smooth or do they have a rough feel? if smooth replace and it should be good as new.
Good luck
Nov 29, 2007 | Philips PPF-575 Plain Paper Inkjet Fax
Fax rollers
try cleaning the rollers with alcohol, they may be dirty and slipping when trying to grab the paper.
If it is too smooth, then they may need to be changed.
Nov 28, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
66 people viewed this question
old marine
old marine
