We had a power surge yesterday. The TV has lost all the net command data as well as now there is a blurred picture. During the original set up there was a code that was entered and this blurred picture went away. Does anyone know this service code. This is a Mitsubishi Projection Television model WD - 62725
  • bsmith639 Mar 02, 2009
    I lost power yesterday and it has had effect on Television. I have a Mitsubishi Projection Television model WD-62725. The picture is blurred. I know there is a service code to enter on the remote control because during the original setup this code was enter and the picture became clear right away. Do you know this code?
  • 19,396 Answers
Try using the auto focus, if the picture stays blurred, then you may have blown something on the convergence circuits, this can happen after a power surge.
Here how to fix the convergence ICs:Fixing Convergence problems in RPTV's
Posted on Mar 04, 2009
  • 4,806 Answers
Hi there.
After a power surge reset the TV as follows >> press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
The SYSTEM RESET button is on the left of the front control panel of the TV itself.
Good luck and thanks for using Fixya!!!
Posted on Mar 02, 2009
    Sergeant:
    Novelist:
  • 277 Answers
Http://www.retrevo.com/support/Mitsubishi-WD-62525-TVs-manual/id/276ag909/t/2/
check out this manual for the programming codes to make the picture proper.but as you described your problem its necessary to get it repaired as inserting wromg codes will totally corrupt the inbuilt memory of the tv forever.
    Genius:
  • 2,035 Answers
Try this:
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
    Genius:
  • 1,550 Answers
Press Menu + 2-4-5-7
for color setups & Geom.
Press: Audio
for options
Press Video
to select the options
Press rewind
for OSD Patterns
  • 564 Answers
Jus give me minute. Let me Check the manual.
I have a vizio vw42L replaced power supply board with brand new board but no picture or sound when the tv comes on my problems with this tv all started because of a power surge any solutions?
After power supply replacement, some adjustments should be done to match the new power supply board. It will be best to contact any experienced service technician, since this work is a skilled one, and have to enter the service mode option screen; which is entirely different to that of user adjustment screen. Adjust the data value to this mode is very crucial, and improper data adjustments might make the TV might not respond to any command signals, either by remote control, or by its front panel control. Entering service menu and adjust data values there is a very skilled work.
Aug 01, 2012 | Vizio Televison & Video
A power outage last night. The tv was off, now it wont turn on. A blinking timer light on the front of tv is on.
Always include model numbers since problems are sometimes associated with particular models. This may be a sign that a line surge during power fluctuations has damaged the power supply. There are a least two supplies in any modern set; a small supply that provides voltage to the remote circuitry and this one is always on. The second supply is the main one that is turned on when the set is to be used. Reluctance to turn on is often a signal that certain components (capacitors) are failing in the main supply and they will continue to degenerate. Try pulling the plug and leaving the set overnight without any power. If a circuit is only 'confused' (locked up) this should reset everything. If it still will not turn on, then either the small supply for the remote circuitry was damaged during a surge or that the main power supply is not responding to the power on command.
Jun 09, 2011 | Mitsubishi Televison & Video
Hi, my sony trinitron Wega KV-32Hs500 will not come on. The stadby light blinks 6 times. I was able to get it on yesterday after repeated turn on, but now won't come on at all. It was working great and had...
common problem. sony makes a power suplly service kit that will repair it. cheap. the power supply is very efficient but ver sinsitive to power surges. easy ans cheap. good picture is worth fixing.
Nov 15, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My TX is about 14 year old. The picture alwasy was excellent until we had an exlectrical storm that knocked out the cable box to the TV. With a new cable box the TV works. The picture has excellent color,...
Try your cable box on a different tv set and also try connecting the cable directly into the t.v, if that makes no difference then your tv set may have a power supply problem that was caused by an a.c line surge during that storm.
Oct 31, 2009 | RCA F19253BC TV
JVC 32" CRT TV BLURRED PICTURE POOR TEXT QUALITY POOR IMAGE DEFINITION CANNOT IMPROVE USING NORMAL COMMANDS
Seems to me you should have to contact a technician to adjust manually the circuit side of it. Usually the screen and focus control knob on the flyback to adjust the settings.
Sep 23, 2009 | JVC AV-32D305 32" TV
Screen froze during lightning storm. no picture now. When powering on screen lights and then dims - no picture, no sound
You might have had a power surge.Try unplugging your TV for 5 minutes and plugging it back in. If you cannot get a picture from any device such as a DVD player and cable then your TV needs serviced call a repair man. Good Luck!
Jul 14, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
After loud cracking noise no picture on plasma
The most likely the TV has a power supply related problem. A power surge can cause the problem. Last thing you want ot do is void the warranty by opening up the TV. Here's info to get your warranty started:
http://www.lge.com/us/support/repair/support-warranty-claims.jsp
Jun 28, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
