Question about Skagen 233XLTTN watch
IS NOT WORKING TOTALLY.
HAVE PUT MY WATCH AWAY FOR WHILE, WHEN I PULL IT OUT OF MY DESK DRAWER, THE FIRST I NOTICE IS THE SECOND HAND IT NOT MOVING AT ALL. MY QUESTION IS THIS WATCH BATTERY OPERATED IF SO, HOW TO GET THE BATTERY. THANK YOU.
  • 2,334 Answers
Yes, your watch is battery driven. The best way is to find your nearest watchmakers shop and ask for replacement. If you want to do it yourself, then open the watch caseback, release the battery and memorise all the writings on battery. You have to buy exactly the same one and replace it.
Posted on Mar 03, 2009
Tissot lelocle is loosing too many seconds a day and second hand jumps several times between second 10 and 25. Is there anything broken?
take it back for a warranty inspection / repair or refund
maybe it is not genuine brand but a knock off in which case the manufacturer would like to be told about
Jun 15, 2017 | Tissot Watches
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
The time is accurate, the chronograph second hand works perfectly, stop and reset to zero. The problem that I notice is that the small hands on the left and right do not reset to zero position
This drove me mad when I had a battery changed! In the manual there was a section on zeroing the Chrono hands on my Seiko. Pull the crown to the first (or may and been second) stop and press the button nearest the dial. Each push will move it one second. Stop when you get to 60 and push in the crown.
Oct 09, 2015 | Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
My watch is keeping accurate time. The send hand holds for 3-4 seconds then moves the like amount. In other words, instead of moving every second it goes in 4 seconds at a time
It is called the "eol" or "end of life indicator" Not yours! Your battery. Notice the time is still correct. This is a feature some better watches have to tell you your battery is about to go dead.
Apr 14, 2011 | Watches
Set date on omega seamaster quartz 1425
When you pull the crown (winder) , you will notice it has two positions (two clicks). The first click is for quick date setting, the second click is for time setting (moving hands). Second click can be use for date setting as well, but for this you need to move watch hands forward for 24 hours to pass 12 o'clock.
Feb 25, 2011 | Omega Seamaster 300M wristwatch
Seconds ticker jumps,stops,jumps
It means that the reserve power is getting low and the energy cell needs to be fully recharged by exposing it to light for a period of time outlined in your owner's manual. This may also occur after fully recharging your watch after a complete discharge of the energy cell. If you have fully charged your watch and the second hand continues to move in two second intervals, you need to do an all reset of the watch. For simple analog models, pull the crown out to the time setting position for 30 seconds, then return the crown to the closed position next to the case, then set the time. For multi-function models, please refer to your owners manual.
Jun 15, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Feb 25, 2009 | Tag Heuer SLR Mercedes Benz Limited...
Stop watch hand
You have to reset your watch. Pull out crown to first click and try to move stop watch hand by pressing one of the pushbuttons. If this do not work, push the crown back in. Now pull out crown fully tto the second click and try to manipulate with pushbuttons again.
After resetting stop watch hand to 0 push the crown in completely.
Job done.
Nov 28, 2008 | Watches
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Skagen 233XLTTN watch Logo
399 people viewed this question
Top Skagen Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
