Question about Ruud UBHC Air Conditioner
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
The Watt Restrictor in my Rheem 11kW Electric Furnace (RBHC-14J11SFA) is shutting off 2 out 3 heating elements, meaning the room I am trying to heat never reaches its setpoint.
Consequently, the furnace fan and a single heating element runs continuously, never reaching the setpoint.
Each morning, the room is around 56F, the setpoint is 65F. It takes 90min to reach 61F, and it does not get any warmer. Assume the outside temp is around 15-20F.
I used a current clamp to verify only one heating element is energized MOST of the time; however, the other two elements do turn on for short periods before turning of again.
Is there any way to safely disable/override the Watt Restrictor? I want to prove that the three heating elements can achieve the desired temperature rise.
Note: I have a Lux single-stage thermostat. Wiring of the thermostat matches the recommendation on the furnace's wiring diagram.
  • 3 Answers
Unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Posted on Mar 07, 2009
I have a Ruud Achiever 90 Plus Gas Furnace with Air Conditioner. I have a new Nest Thermostat. What is the correct wiring connections on the Furnace?
A Ruud Achiever gas furnace I believe came in a two stage model for heating. What this means is that you will have a high and a low setting. Your furnace should have two wires that control the heating cycle a W1 and W2. This should correspond with the terminals on the nest thermostat. You may run into issues if you do not have enough thermostat wires to control the furnace. If you are ever in the need for Ruud And Rheem Gas Furnaces we offer a great selection online. Shop Natural Gas Furnace. We also have a chat line which can provide technical support.
Dec 26, 2017 | Ruud Heating & Cooling
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-14J11SFA. What size replacement filter can I put in this system?
You can measure what size and use any after market permanent filter. Measure the opening to the rear and across the opening. Should read as ?x?
Dec 03, 2014 | Ruud Heating & Cooling
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
The furnace shuts off before set temperture is reached
This could be normal. Some thermostats are designed with a heat anticipator. The anticipator takes into consideration heat that will remain within the system after the burners shut down, it anticipates the "left over" heat will be enough for the thermostat to reach it's setpoint. If it did not have this function the setpoint would be overshot.
If you are suggesting it shuts off well below the desired setpoint please clarify.
Dec 01, 2009 | Honeywell Electronic Programmable...
Ruud UBHC-21J18SFA blowing only "luke warm" air at best
That's crazy, we're having the same problem.  Turns out there was a wattage restrictor in the furnace that was switching off 3 of the 5 heating elements in an attempt to save energy.  Basically, the restrictor was sensing that the incoming air was warm, so only 2 of the 5 coils should be needed to heat the air.  Well that wasn't enough and we just sat with the furnace running all day long struggling to reach the 70 degree setpoint.
This is something a technician can diagnose in a few minutes, but not the sort of thing a DIY'er should really handle.
Dec 22, 2008 | Ruud UBHC Air Conditioner
Cannot reach the temperature setpoint in heating sequence
I think what you are trying to ask is should you use a 2 stage thermostat or stick with a single and just double the stages on a relay to work at the same time. As long as the relay can handle the amp load, there is no real need for a 2 stage heat system, unless you are concerned by the efficiency of $$. If I am missing the question please reply.
Dec 11, 2007 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
1,359 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
