Question about Hotpoint Ultima WF860 Front Load Washer
How do I replace Drum paddle on Hotpoint WF860 washing machine
The drum paddle/lifter on my Hotpoint Wf860 has fallen off. I am going to order a new part ( drum paddle version 3 ) but I need advice on whether I can fit it myself or will I need to call out an expert. I would be grateful for any advice regarding this. Many thanks.
  • Hotpoint Master
  • 3,463 Answers
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Posted on Mar 02, 2009
  • anne pollard Aug 16, 2013
    how do you know which is the right way round .
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Posted on May 06, 2010
How can i replace the drum lifters in my Bush A147CR6B washing machine?
They are hard to replace. Be careful and wear a pair of goggles. You must be strong and careful when doing this. A pair of mechanical pliers and a long slender strong flat edge screwdriver will do the trick.
Jan 12, 2014 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint AQXXF149PM washing machine, and two of the drum paddle lifters have fallen out.I have the replacement parts but cannot work out how to fit them, as a piece of metal projecting at 90...
I have exactly the same problem on my ...129 model. I'm a mechanical engineer and looking at the design it apears that these aren't designed to be replaced. The 90 degree tab looks to be only accessed from the outside of the drum so can only lock the tumbler in place from the factory. It needs to be bent flat to get the paddle on!
I hope someone can prove me wrong??
Jun 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
Agitator has come off in the drum, can it easily
Yes,it is easyly replaced.
You will have get a new one, do not try to refit the original, as it will come off again.
You just simply slide it into the slots in the drum, and push it firmly into place, you should hear and feel it click into place.
Hope this helps you.
Dec 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Oct 19, 2009 | Indesit W 123 Front Load Washer
Lifter broken on Hotpoint BHWM129 - replacement on order but need to get the old one out Hotpoint says its easy to do but I am stuck - its a twelve hole lifter and I cant find out how to release the...
Grasp it firmly with both hands, and pull it towards you, it requires quite a bit of effort to do this.
Fit new one by pushing it in and towards rear of drum until you feel it click into place..
Thanks.
Jul 30, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
2,812 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
