Question about Acer Aspire 3610 Notebook
After replacing my broken screen on a Acer Aspire 3610 15.4 I have no display ,only back light on the screen, It will come up on a cpu to the opening screen then blank . I have the origional cables to the screen and the inverter . I am lost Don
  • 1 more comment
  • williesman7 Mar 02, 2009
    Hi There , When I turn on the Acer the screen lights a clear silver all over and that is all ,no words or pictures , when I hook it to a External monitor I get a start up screen and then blank .
    It did work befor I changed screen cause it was broken and 1/3 not seeable .
    Thanks Don
    I may not be clear, using only the laptop screen with nothing outside hooked up the screen is a silver clear when it lights .
    the only way to see a start up is with a desk top monitor
    The monitor will show a start up and then go dead
    Thanks Don
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Can you please describe what you see on the screen?
  • Acer Master
  • 4,806 Answers
Hi there.
It sounds like you have not connected the ribbon cable that goes from the inverter up the back of the screen properly, unscrew the bezel (plastic screen surround) and check the connections are snug and tight, also check the block connector on the motherboard. Once you are satisfied that all the connections are good, re-assemble the lid and turn it on again, if you still get the same problem check the inverter, if the inverters fine it could be the graphics chip itself which is defective.
Good luck and thanks for using Fixya!!
Posted on Mar 02, 2009
    President:
  • 2,653 Answers
If you get a normal ACER screen boot then it goes dim, then your inverter is probably bad.
Just swap the inverter and you should be back in business.
White lines in my screen and broken display
If it has been damaged, order a new screen through flea bay or gumtree and follow the online video on utube of how to replace your screen.
Jan 19, 2014 | Acer Aspire Computers & Internet
Dark laptop screen inverter and lamp ok
It might be necessary to send it in to Acer for their technicians to look at it as they have parts there. The damage of the display panel many have damaged other parts as well I would suspect the ribbon cable that feeds the display from the main body section. Is power getting to the inverter? Look at the items you have not compared with the other unit such as a ribbon cable- what else is there?
Sep 26, 2012 | Acer Aspire 5630 Notebook
Does ACER ASPIRE One 11.6" have camera ?
Yes'
General Brand Acer Series Aspire One Model AO751h-1401 Part# LU.S780Y.002 Operating System OS Provided Windows Vista Home Basic Processor CPU Type Intel Atom CPU Speed Z520 CPU L2 Cache 512KB Chipset Chipset Intel SCH US15W Display Screen Size 11.6" Widescreen Display Yes Display Type WXGA Max Resolution 1366 x 768 Display Feature LED backlight & Acer CrystalBrite Technology Graphics Graphics Processor Intel GMA 500 Video Memory Shared system memory 2GB Hard Drive HDD 250GB Hard Drive RPM 5400 RPM Hard Drive Interface SATA Netbook Camera Camera Type Acer Crystal Eye webcam Communications LAN 10/100Mbps WLAN 802.11b/g Wireless LAN Expansion / Connectivity USB 3 x USB 2.0 Video Ports 1 x VGA Audio Ports 1 x Headphone/Speaker/Line-Out Jack 1 x Microphone-in Jack Audio High-Definition Audio Support Speaker Built-in stereo speakers Input Device Touchpad Multi-gesture Touchpad (Circular-motion scrolling, pinch-action zoom, page flip) Keyboard Standard Card Reader Battery 3-cell Li-ion Battery (2200 mAh) Battery Life Up to 4-hours Manufacturer Warranty Labor 1 year limited Parts 1 year limited
Oct 14, 2011 | Acer Aspire One AO751h-1401 11.6-Inch...
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
My screen is black but when i use a second monitor, its working perfectly. How do i solve this problem? My laptop is a Acer Aspire 3935.
The problem is either a bad inverter board "more likely" or the back light behind the screen has failed. The inverter is located under the LCD screen, and the back light usually requires the whole display to be replaced because it is built right in.
Mar 29, 2011 | Acer Aspire One PC Notebook
I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
Feb 19, 2010 | Acer Aspire 4520-5582 Notebook
I'm trying to open up an Aspire 5516 and I have all the screws out I think but it won't open up.
Go to Youtube and search under Acer 5516 cpu upgrade. There is a video showing you how to open an Acer 5516.
After you take out all the screws on the bottom. You still have to take off the keyboard, the display screen, the battery, the memory, the harddrive, the dvd drive, and the modem.
Feb 15, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3630 screen problem
most probably the lcd screen is broken
Mar 31, 2008 | Computers & Internet
Acer Aspire 3610 Notebook Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
