Question about Microsoft Xbox 360 Controller
Xbox 360 left analog stick
I start playing call of duty and i can move with the left stick but when i click down i cant run and it uses knife attack for bith analogs
  • dan_ov_hull Mar 03, 2009
    Where do i find the controller settings, i cant find it!
  • firethefirst Mar 22, 2009
    my left stick is busted or something. i can't click down on it so i can't run in call of duty. and when i move it, it just stays to one side and doesn't snap back too the middle.
  • 20 Answers
I might be able to help... go on to setting go to controller setting and you will have multiple different ways your controller will work look at the one it is at before you change it then try different controller setting if that diddent work write back ;)
Posted on Mar 03, 2009
  • treedom Mar 04, 2009
    umm go on to your xbox menu by pressing the X button and look for settings and in the setting options there should be controller settings
    press the X on your controller to go to your menu then find the settings and ithin the setting options there should be controller settings hope that helps:)
Right analog stick xbox 360 controller faulty
Possible problem,is in the wire connecting the controller to the consol...thanks..Dods
Sep 28, 2013 | Microsoft Xbox 360 Wireless Controller
My left analog stick button won't work on my Xbox 360.
Try using the stick on the Xbox Dashboard. If this doesn't work, you need to use a different controller or attempt to repair your controller.
Jan 21, 2013 | Microsoft Xbox 360 Console
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
Controller not working. On Call Of Duty Black Ops, whenever I move the bottom analog stick up, I look down.But If I move the analog stick down I look up.
Go to the game's controller settings and select which configuration suits you. Don't set it to inverted if you are not used to it.
Hope this helped you!
Rate my answer if you appreciate it.
Sep 09, 2011 | Microsoft Xbox 360 Controller
The left analogue stick keeps moving the character around even when im not doing anything
Hello alsupjonatha,
Aug 07, 2011 | Microsoft Xbox 360 Controller
Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Apr 04, 2009 | Microsoft Xbox 360 Wireless Controller
Left analog stick click will not work
i might be able to help this may just be a controller defect meaning the controller might not work.. but first go on to your setting than look for controller setting change the controller setting then change it back to the one you were on ion the first place ... hope that helps:)
Mar 01, 2009 | Microsoft Xbox 360 Controller
The left analog stick on my xbox 360 controller is faulty
In this game you must check your settings, you may be set to right handed in which case movement/advance is on the right side and attack is on the left. You should be able to go to settings and change the settings to make the left analog control your movement. Hope this helped and if it does, don't forget to leave feedback....FIXYA!
Feb 14, 2009 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
3,075 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
