Question about Intel Asus mobo Motherboard
SIGMATEL 9220 6-CHANNEL 5.1 SOUND CARD ADAPTER,, clean xp install, "no audio device" prevails, tried to rid legacy audio drivers, changed bios, worked on device mgr, installed dyney pci card drivers wont replace legacys. disgusted jack
  • 447 Answers
After doing a quick check for that chipset I found this download on the Intel site which should cover the 9220 audio device.
Report your results or error messages back here so we may further assist.
Posted on Mar 02, 2009
Bad mother board
I can't installed it
Windows XP should load drivers for the card automaticly, you may want to upgrade you system to SP3 if you havent already, Go in BIOS before start up and uninstall your onboard Audio driver under Onboard Periferals, click disable/turn it off, If you have an XP instulation cd you may be able to point windows to the Legacy driver.
Jul 17, 2012 | Compaq Creative Sound Blaster PCI 128...
There is no sound from the pc
Try to uninstall the audio driver and restart your PC manually, and install the driver again.If the problem is same follow the second,
Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System Properties-window)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers and others are not in Questioned Mark (?) symbol with yellow color. If there need to install the drivers).
Or
You can roll back the driver.Follow the bellow link.
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx
Or
If same as before can restore the system. Follow the bellow link.
For Win 7
http://vlaurie.com/computers2/Articles/windows7-system-restore.htm
For XP
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the problem is same , reset your BIOS SETUP.
Please follow the instruction bellow.
Restart
Press Del/F2/F10 right after starting the computer for BIOS setup.Follow the bellow link.
http://www.computerhope.com/help/phoenixa.htm
Just enable on board audio device. If you think it is difficult, set it default or load fail save default.
I always suggest to set load fail save default >F 10(F key)>yes. Now install the driver again. I
If the problem is same is before please,use an USB audio device.
Follow the bellow link and its not expensive.
http://cgi.ebay.com/USB-2-0-EXTERNAL-SOUND-CARD-3D-5-1-AUDIO-ADAPTER-PC-/290521187269?pt=LH_DefaultDomain_0&hash=item43a46983c5shibuda_29.jpg
Hope this helps.
If you need more information, reply me soon.
Thanks
Feb 27, 2011 | HP Compaq nc6120 Notebook
Toshiba satellite pro c650-d5010 win xp audio not working.
Hi friends,
Uninstall audio driver and restart your PC manually and install the driver again.Hope it will solve the problem. Please check the next steps. To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). Or you can roll back the driver, http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx Or can restore the system. http://vlaurie.com/computers2/Articles/windows7-system-restore.htm For XP http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If you will face in same problem, reset your BIOS.
Restart
Press Del/F2/F10 right after starting the computer for BIOS setup http://www.computerhope.com/help/phoenixa.htm
You will do enable on board audio device. If you think it is difficultto set please do the
next.
I always suggest to set load fail save default >F 10(F key)>yes. Now installthe driver again. If the problem is same is before please use an USB audiodevice.http://cgi.ebay.com/USB-2-0-EXTERNAL-SOUND-CARD-3D-5-1-AUDIO-ADAPTER-PC-/290521187269?pt=LH_DefaultDomain_0&hash=item43a46983c5shibuda_29.jpg
Thanks
Feb 25, 2011 | Computers & Internet
No devices are shown when go sound and recording
Hi friends,
Uninstall audio driver and restart your PC manually and install the driver again.Hope it will solve the problem.Please check the next steps.
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System Properties Window)
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers and others are not in Questioned Mark (?) symbol with yellow color. If there need to install the drivers). Or you can roll back the driver, http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspxOr can restore the system. http://vlaurie.com/computers2/Articles/windows7-system-restore.htmFor XP http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the problem is same , reset your BIOS.
Please follow the instruction bellow for bios setup
Restart
Press Del/F2/F10 right after starting the computer for BIOS setuphttp://www.computerhope.com/help/phoenixa.htm
And enable on board audio device. If you think it is difficult to set please do the
next.
I always suggest to set load fail save default >F 10(F key)>yes. Now install the driver again. If the problem is same is before please use an USB audiodevice.http://cgi.ebay.com/USB-2-0-EXTERNAL-SOUND-CARD-3D-5-1-AUDIO-ADAPTER-PC-/290521187269?pt=LH_DefaultDomain_0&hash=item43a46983c5shibuda_29.jpg
Thanks
Feb 22, 2011 | Dell Inspiron 1525 Laptop
My lapy has sound problem
• Go to Start>
• Control panel>
Restart
next.
Feb 19, 2011 | Computers & Internet
No drivers for the sound provided by sigmatel
Here is a link to all of the drivers for that motherboard. You should also see the drivers for the audio as well. I would suggest downloading the drivers and making a backup cd when everything is working.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2068&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!#DRV
Apr 15, 2009 | Intel D945GNTLKR/945G/A&V&GBL/RAID...
Onboard sound card driver
hi did you try this ??
http://www.downloadsource.net/7653/SiS-7012-Audio-Chip-Driver-Windows-9x-NT4-2000-XP-32-bit-XP-64-bit-2003-64-bit/
Sep 15, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Dell Inspiron E1505 Audio
Hi artifax,
I have a suggestion/solution for this that I need you to try. Here it is:
first, go to add or remove programs, look for Creative/SoundBlaster and Sigmatels listed there and uninstall every one of them. Then, go to Device manager and uninstall Creative/Soundblaster/Sigmatel under sound and game controllers. reboot the system.
now download and run this,
E1505/6400 BIOS
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R158849&SystemID=INSPIRONI6400/E1505&servicetag=&os=WW1&osl=en&deviceid=10430&devlib=0&typecnt=0&vercnt=9&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=212350
then download and install this,
Sigmatel Audio Driver
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R171789&SystemID=INSPIRONI6400/E1505&servicetag=&os=WW1&osl=en&deviceid=8907&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=235761
Do not install any Creative first, then let me know if this works.
I'll be waiting for your reply.
Karlox™ :)
Jul 28, 2008 | Dell Inspiron E1505 Notebook
I have no sound in my PC
BrendanG21, I had the same problem this morning. My sound actually quit in the middle of listening to music. Simply restart your computer (it may take a couple tries). If it's saying you have no audio device installed, but everything looks normal when you go into device manager, it's probably the same problem and this should work.
Running Windows XP
Dell B130 laptop
Sound devices listed under my device manager:
Audio Codecs
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Jun 23, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
Computers & Internet Logo
176 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
