Back to:
Tags:
Rane SSE-35 Home Equalizer
Looking for parametric EQ
By Horner - usenet poster
I am looking for a 4 - 5 band parametric EQ for a home theater
application.
Does anyone have a recommendation?
I noticed that most of the parametric eq's do not have 1/4" RCA jacks,
is this because
most of the parametric eq's are used in recording studios?
I have a problem in the 60 100 hz range.
I have a Rane SSE35 EQ and I can not attenuate
that range of frequencies enough. The rane can only attenuate -6db, I
figure I need
at least 12 more db of attenuation. I was hoping I could use a
parametric eq to notch out
the problem frequency and bring down the whole band to within reason.
Any help would be appreciated.
Norm G.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Odud
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you got that much of a problem down there, there ain't any EQ in
the world that will solve it. Fix your room acoustics so you don't
have that standing wave problem.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Looking for parametric EQ:
I don't want to Accept this solution
Can you Help with these Equalizers problems?
Equalizers
Hola, los molesto desde Argentina para saber como conecto...
Equalizers
qwesfWDR3
Equalizers
my external monitor does not recognize  the cursor/...
Equalizers
hi! can you upload the manual (in Spanish, of course)?...
Equalizers
i need the remote control settings to set my picture size...
Loading problems.
Repair Service
Find Equalizer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
