Question about AMD ATHLON 64 POWER SYSTEM (AMDATH64) PC Desktop
Wierd display problem/graphics card issue??
When i turn the computer on i gets lots of random jumbles of wierd characters and colors all the way from the startup to desktop. when i get to the desktop there are lots of horizontal lines of different colors and once in awhile ill get the blue screen of death. i tryed reformating the hard drive but no luck.
  • Clint siebert Aug 02, 2007
    i origanally had 2x geforce 7800 gtx graphic cards and one was bad so i sent it to the company and this is my last one, it was doing fun up till now.
    and i tried moving the graphic card to another slot, i checked my moniters menu and the menu is just fine!
    Problem Solver:
  • 16 Answers
There are two possible reasons either it could be the problem with the graphics card or monitor. To check that.. While this problem occurs. Just press the menu buttons on the monitor, if this horizontal lines and different colors are shown on the menu also then its the problem of monitor else with the graphics card or motherboard. Give it to the nearest service center. before that just remove the graphics card,wipe the card and slot with a clean cloth and install the same n check.. Please rank me ShaC
Posted on Aug 02, 2007
  • 65 Answers
Have you tried replacing the video card?
SOURCE:
Laptop has jumbled horizontal muli-colored lines flickering and rolling, can't see screen
You should try to connect a VGA monitor to your laptop and see what happens. It sounds like a video card failure, and often the hdmi and the VGA are powered by different graphics chips.
If it works with a VGA monitor, try to install a new driver for your graphics card. Otherwise, try a system restore. That often solves your problem.
If a restoration doesn't help, your graphics card is probably broken. Get a new laptop. Avoid Acer :)
Feb 15, 2013 | Acer Aspire Computers & Internet
Hi, i just bought the Diamond RADEON HD 5770 graphics card. everything throughout the installation went smoothly. when i run games (video works fine, as well as basic web browsing) the screen will...
it may not be your GFX card...depending on what kind of windows you have..like 98 DOS or windows vista or windows 7 your GFX card may not support that type of windows...hope it helps..if not..sorry...but i'd try to download a different version of windows..
Aug 13, 2011 | Computers & Internet
Hi I have an acer Aspire 1690, which will not start. My guess is that the graphics card has had it as the screen displays lots of bizarre characters and colours and the BSOD comes with a ati2dvag infinite...
Most Acer laptop graphics cards are not upgradeable. In fact most laptop graphics cards are not upgradeable in general. Usually if it does not say that you can upgrade then it can not be replaced or upgraded, however I would give Acer a call and see if they can do anything for you especially if it's under warranty.
May 08, 2011 | Acer Computers & Internet
Corrupt portable drive
I had the same problem with my WD passport. Most of the folders displayed wierd characters and couldn't access those folders. Thanks to Zero Assumption Recovery software, I had successfully recovered all my files. Check this link on how it works:
http://www.z-a-recovery.com/unformat-tutorial.htm
If your hard drive is detected by your computer you can use this software for data recovery.
Thanks
Sid
Nov 13, 2008 | Western Digital Passport WDXML800UE...
Computer display jumbled and unreadable
From what you describe, I'd suspect the Graphics processor, or even the motherboard as a source of the problem if the monitor works on a different system normally (Best way to check the monitor is a known good video source)
If it is the system, and the system is 8 years old, I'd recommend replacing the system rather than attempting to fix it. Trying to fix GOOD parts for an obsolete system is difficult at bst and oftern can be expensive. Often you can find a low end NEW system (One that is like 20 times faster than the failing system) for less than $300
Oct 18, 2008 | Computers & Internet
Display Problem
First things is to see if the problem is
  1. memory related(these all in one units have a problem that way.)
  2. Run everesthome and update chipset<NORTHBRIDGE>Google the northbridge for updates.
  3. nVidia GeForce FX Go5700 problem.Make sure all updates for graphic drivers have been installed, then attach an external monitor, the unit should support svga/dvi/s-video. Your graphics card has 128MB dedicated so if the external display responds the same way as internal monitor it's the video card or chipset.
May 07, 2008 | Sony VAIO VGC-V517G PC Desktop
Display won;t turn on from a reboot
to: Svodon,
it shows that you the video card you installed having loose contact try to dismantle then clean with pencil eraser the contact points(bronze color) on both sides wipe with clean cloth make sure no residues of eraser before you install to prevent mis contact. after cleaning make sure you will install firmly. ihope this will help your problem and hoping your positive response
Nov 06, 2007 | Nvidia GeForce FX 5200 Video Card Graphic
AMD ATHLON 64 POWER SYSTEM (AMDATH64) PC Desktop Logo
Top AMD Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
pankaj rautela
pankaj rautela
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
