Question about Roper REX4634KQ Electric Dryer
How far can you run a dryer vent on a Roper dryer?
  • Roper Master
  • 8,220 Answers
6 feet at most
Posted on Mar 02, 2009
My roper dryer will run for few minutes and throw a breaker.It gets hot and spins just throws breaker
check the vent i went on one that done that if vent is clear and no other signs replace breaker
Jun 08, 2010 | Roper RES7646KQ Electric Dryer
Runs but doesn't heat
check dryer hose u might have pushed dryer back too far and kinked hose or have a buildup of lint in the dryer vent if not check for continuity thru ur overheat safeties theres usually 2 or 3 of them on the element housing an they r round UNPLUG UNIT AND TAKE THE 2 WIRES OFF 1 switch at a time and chech and make sure u have continuity thru all of them but its probably gonna be in ur dryer vent unhook it from thee back first and try to dry a load if so u have a kink or too much lint in vent
Feb 24, 2010 | Roper REX4634KQ Electric Dryer
My roper dryer will not dry all the clothes in one cycle.
try runing your dryer with out the vent hose.if your dryer wooks well than you have a problem from were the vent hose hooks up to your dryer and the outside vent.
Nov 17, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer will not start it is electric
The thermal fuse is probably open again, This condition is caused by restricted air flow out the vent system. Replace thermal fuse again and clean the vent hose and vent hood outside
Jan 05, 2009 | Roper REX4634KQ Electric Dryer
Dryer steaming up my house
ck vent againalso be sure dryer is not pushed back too far crimping vent hose..to double ck leave rear vent hose off and dry a load ..may be some lint and moisture in house but if dryes in mormal time will confirm vent problem ..vent may only be partially blocked also look for hole in vent hose or better yet replace entire vent hose
Oct 27, 2008 | Roper RGX4634KQ Gas Dryer
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer
YOU HAVE A VENTING ISSUE WHICH CAUSE SLOW DRY STEP1 REMOVE LINT FILTER AND CLEAN WITH HOT WATER AND SOAP STEP2 MAKE SURE YUO'RE NOT CRUSHING YOUR VENT HOSE BY HAVING DRYER PUSHED TOO FAR UP AGAINST WALL STEP 3 CHECK OUTSIDE VENT TRAP IS NOT OBSTUCTED BY LINT IF THESES STEP DOESN'T WORK HAVE PROFESSIONAL CHIMNEY SWEEP INSPECT AND CLEAN VENTS
May 28, 2008 | Dryers
Roper dryer
if you are sure vent is ok ..did you try a load with vent disconnected??...there is a chance there is something blocking air flow in lint screen/blower housing ..remove the 2 screws under filter remove all back screws remove 4 screws holding blower housing in place ..you then can pull complete housing out back
May 18, 2008 | Roper REX4634KQ Electric Dryer
What would cause intermittant heating in a Roper Electric Home Dryer?
the dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
Nov 20, 2007 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
102 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
