Question about GE 46GW947 46" Rear Projection Television
Projection not functioning properly
GE, 46gw947 model#, has problems with projection. Can be temp fixed for about a minute by adjusting projection. 2nd problem, sometimes the sound will go out on the tv, but be ok when using the dvd.
    Scholar:
  • 85 Answers
This is a common problem in the projection tv faced by many users.that the sound goes out and comes properly when using dvd player on it.but its the problem of weak sound ic on the main board of the tv that has to be replaced its also called the audio ic. as the sound only comes because the dvd itself has its sound ic in the device so the sound comes from that ic which you get.
Posted on Mar 02, 2009
Adjusting the focus
If the model number is correct is color (ge 46gw947) 3 d or skewed looking?
Apr 13, 2012 | GE 46GW947 46" Rear Projection Television
Need new IR Sensor for a GE 46GW947 rear projection. Is this part enterchangeable with any other TV or brand?
ALMOST ANY RCA OR GE MADE AT THE TIME WILL USE A COMPATABLE ONE.
SENSOR IS LOCATED ON TINY PC BOARD IN FRONT OF CRT LENS.
sd tech
May 13, 2011 | GE 46GW947 46" Rear Projection Television
Convergences not linning up and bowed after replacing a blown fuse
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Apr 15, 2011 | GE 46GW947 46" Rear Projection Television
Is there a reset button for the GE 46GW947?
There is NO reset button for this model.
Let me know what problem you have and I will assist you.
If I have helped rate this solution as very helpful as I do this here for you for free.
SD TECH
Aug 17, 2010 | GE 46GW947 46" Rear Projection Television
Closed caption display will not turn off!
Are you using this TV with a cable box, satellite receiver or DTV converter? Some models of these devices include closed caption decoding. You may have the function turned on there.
May 18, 2009 | GE 46GW947 46" Rear Projection Television
BIG SCREEN
you can get one at the following link. Leave them an email with your model number and they will get back to you within minutes.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | GE 46GW947 46" Rear Projection Television
Rear Projection
They are under the picture setting in the adjustment menu
Apr 05, 2008 | GE 46GW947 46" Rear Projection Television
GE projection tv
CONTRAST ADJUSTMENT IS ON THE FRONT CONTROL ON TV
Projection tv
Dear Sirs..
I have a GE rear projection TV and would like to know where the contrast adjustment is ?
Thank You Brian
Apr 03, 2008 | GE 46GW947 46" Rear Projection Television
Need to warm up????
Sounds like something wrong in the tuner circuit How about performing a by-pass test? Use the A/V 1 or 2 inputs on the bottom rear of tv to hook-up signal.Use dvd or source box.When the set is cold,turn on and check.If the pix & sound are good,then the tv has a tuner problem. If you can live with two inputs,no repairs need to be done.Caution:observe funky,side-ways hook-up on A/V 2 !!!
Oct 05, 2007 | GE 46GW947 46" Rear Projection Television
GE 46GW947 46" Rear Projection Television Logo
102 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
