At the beginning it didn't shut the phone off. I've removed the battery, thought it might be a software glitch... Only then (after put battery back) I couldn't switch it on back.
It looks like the switch is broken or something like that.
a. Is there anyway I could switch this phone ON? b. How can I reach and do something to fix this switch without spending money?
I'll thank you for quick reply if you can Thanks, Ami
Switch off the phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the phone. Enter the default code 12345 or 00000. Your phone will be unlocked
The default security code for Nokia is 12345 IMEI: 353664011528698 Master code: 3564155064 Close all applications on your phone. With your phone switched ON, remove the battery. Then remove the SIM card. Replace the battery without the SIM card and switch your phone on. Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code. This is the code needed to reset the Security code, nothing else, and it’s for your phone only. If it doesn't request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
The default security code for Nokia is 12345 IMEI: 353235015522555 Master code: 2564610140 Close all applications on your phone. With your phone switched ON, remove the battery. Then remove the SIM card. Replace the battery without the SIM card and switch your phone on. Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code. This is the code needed to reset the Security code, nothing else, and it’s for your phone only. If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
first of all amke sure the phone battery is fully charged. Now follow thw following steps:-
1. switch off the phone
2. press and hold down the *, 3 and the Call answer key and switch the phone on
3. don't release these keys until you see a Formatting........ message
4. your phone will be restored with the factory settings
hi there you have togo to your nearest service center to remove the security code they will reset your phone but till them first if they have a software to read the security code of your phone so all the data and contact wont be erase cuz once they reset it all data and contacts of your phone will be erase.
Nokia only supports Windows 2000 and newer for your Phone-software.
So you have to upgrade your OS to make use of the PC-Suite.
There might be a 3rd party software somewhere that might work for you but the chances are very low, since the phone is rather new and Windows 98 is quite "old"...
Microsoft even stopped supporting Windows 98 a while ago, so theres not many chances that youre going to make this work.
Will someone help, pleae
same problem in nokia 5310 phone
