Question about HP Laserjet 1500/2500 High voltage PS Printer
HP 5200 Laserjet printing is not done fast. If we give a command of 800 KB file than it takes half hour tell me what the problem is
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Posted on Mar 02, 2009
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Good day i'm having a freezing problem with my printer if i send 10-100 prints it processes then prints half the job and then freezes with processing written on the screen please help!
Dear Sinclair
The freezing occurs due to two things.
1- when you command print file size is more than the buffer RAM of the printer. ( it will solved choosing page no. selection to print). If there is option to increase the RAM of printer, may be up graded.
2- Fixing temp. when exceeds predetermined temp. it takes a short time may be neglected.
Thanks.
Mar 18, 2015 | HP LaserJet 5200 Printer
HP 5200 prints light at beggining of page then prints normal.
Print half way test page.,chk leading edge is same as you noticed?..
If yes: Chk transfer roller, clean it, chk side locks..if required replace it..
If no: chk fuser Teflon sleeve., is there toner deposits in surface? Replace Teflon sleeve if available or else replace fuser assembly..
Half way test page:
browse: http://www.printertechs.com/printer-troubleshooting/halfway-test
May 13, 2014 | HP LaserJet 5200 Printer
Copying without command
Sir/ Madam
I think You Give Lot Of Print Command And Mistakable Turn Off Your Printer Whats Why Whenever You Turn Your HP Printer Connected With Computer It's Start Copying And Printing By It's Self,So I suggest You To Cancel All Print And Copy Commend By Pressing Cancel Button Or Follow The Step On Below URL Link:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5071505&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c02476541-10%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Or
Follow Us For Hear For HP Printer Support
Jan 08, 2014 | 2SToner HP Laserjet Pro M1213nf Printer...
Printer chews up paper when it is printing. Can this be rectified?
Step 1: Take half test page check is there any symptom what you are getting? If yes replace with another cartridge check...( How to take half test: Give fully mattered print command while printing switch off the power remove cartridge take out printed paper check the printed matter on page) Step 2: If found cartridge is OK, 95% suspected Teflon sleeve( a cylindrical sleeve which is coated grey colored Teflon), replace it if available if not replace with new fuser assembly..
Nov 18, 2011 | HP LaserJet 3015 All-In-One Printer
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again...
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
Mar 16, 2011 | HP LaserJet 1020 Printer
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
P2015DN Left side of image cut off
If this is a HP LaserJet P2015dn Printer try the 24 hour # listed below.
I've spent countless hours trying to install solve printer problems by going on line but I eventually solve the problem when I break down and call the 24 HOUR NUMBER!
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products
Be prepared to provide the following information: Serial Number (S/N), product name, model number
HP TouchSmart PC products
866-408-5408
24 hours a day, 7 days a week. U.S.: English and Spanish.
Compaq Presario PC products 800-OK Compaq
or
800-652-6672 24 hours a day, 7 days a week U.S.: English and Spanish. Customers using TTY 877-656-7058 6:00 a.m. - 3:00 p.m. PT
Mon. – Fri.
excluding holidays
Dec 15, 2008 | HP LaserJet P2015dn Printer
Slow printing of Acrobat pdf files on HP Laserjet 1300
Ok this is simply because of the printer spooler and because PDF's are much larger that is why. Here are the instructions on how to print another way to print a little quicker.
Sep 26, 2008 | HP LaserJet 1300 Printer
77 people viewed this question
Ben Johnson
