Question about Haier HWD1000
It is displaying error 7
The washer has worked well, but all of a sudden it doesnt and now says error 7, what does this mean?
  • 3 Answers
100% motor , you may try the carbons, need help phone 0161 355 8254 , thanks , hope this helps
Posted on Mar 04, 2009
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
What do's the code f21 code mean
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Apr 10, 2011 | Washing Machines
My front loader washer is blinking the f21, what does this mean?
F21 LONG DRAIN
kinked.
Apr 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
If there is anyway i could get a free answer omg it would be appreciated! what does the error code on a whirlpool ht f 21 mean? please help.
F21 LONG DRAIN
kinked.
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does code F 21 mean
F21 is:
LONG DRAIN
NOTES:
Press PAUSE/CANCEL two times to clear the display.
kinked.
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does Troubleshooting "F" "02" mean
F02 Long drain If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
8. Replace the pump.hope this helps
May 01, 2010 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
kinked.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Error codes
when the power is turned off for a period of 30 mins and then restored does the machine still display this error code as soon as you try and start the machine,o and by the way does the door lock?
May 03, 2007 | Indesit W 123 Front Load Washer
Haier HWD1000 Logo
441 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
