Question about Xerox WorkCentre M20i All-In-One Laser Printer
Xerox workcentre m 20i does not power up - Xerox WorkCentre M20i All-In-One Laser Printer
    President:
  • 2,072 Answers
First of all try unplugging it for a half an hour. Not just turning it off but remove the power cord. Very often there is a capacitor in that power supply filter you have to let discharge totally.The only way that will discharge is to remove all power for a half an hour.
A dead machine otherwise , would he a bad power supply. It is located under the cover where the copies come out. There is also a couple of fuses on that power supply. To access it, go to the left side of the machine, the side where the on off switch is and remove the 2 silver Philips screws on that side. There is also a tab on that cover, so don't be afraid to pull it pretty hard to remove, It will Pop, but not break. There are 3 screws in the metal cover over the power supply to remove the cover, check the fuses, if they are good the power supply is bad. Google a business called The Parts Drop, call Britt and he will have that part. There is a really good chance that unplugging it for the half an hour will work. I have taken tons of calls and canceled calls where that is all you have to do. Let me know please.
The main board is highly unlikely to cause a dead machine, very unlikely. Actually it can happen, but I have never seen a main board cause a machine to be dead.
Posted on Mar 02, 2009
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Try powering down then on again please call for assistance
WorkCentre 4250 Support - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-4250/.../enus.html
XeroxProduct support for WorkCentre 4250. ... WorkCentre 4250 Support & Drivers. Fast Track to the Expert > Contact an experienced service technician ...
Jan 22, 2013 | Xerox WorkCentre 4250
-Xerox workcentre m20i. -Yesterday turned machine
hi enviro,
so its the supply inside the Xerox is the next to be checked or fuse too..a technician nearest you can help open it.
mastergani
Jan 21, 2011 | Xerox WorkCentre M20 Black and White...
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre xd100 copier NO POWER
hi,check power cord if the power cord correctly connected the problem is power supply.
Apr 26, 2009 | Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
289 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
