Question about Konica Minolta Office Equipment & Supplies
Kinoca Minolta Di2510 Double-sided printing
I need to ''print'' duplex on a Kinoca Minolta Di2510 PCL6. Is that possible, without having to do it manually?
    New Friend:
  • 11 Answers
Yes it can be done, if the m/c is having duplex unit.
Posted on Aug 17, 2009
Error f-10-1
Posted on Aug 25, 2012
Duplex Error When Trying to Print PDF
I found that one of the papers i was trying to print was set for double sided printing, well i don't have the duplex part of it. So I kept getting the error. You have to cancel all the print jobs thru the buttons on the printer. Doing it in your computer did not help and turning off the printer did not help me. So after I cancelled all docs from printing and turned off double sided printing it was fixed.
Jan 30, 2012 | Konica Minolta magicolor 2300DL Laser...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
Jan 20, 2012 | Konica Minolta bizhub Office Equipment &...
Please i want to know if konica minolta magicolor 1690mf is wireless printer? and how do i set the two sided print.
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
How do you print double sided on a Minolta DI2510 on vista
In print properties select left binding and double side. DOES YOUR COPIER HAVE A DUPLEXER??????
Jun 29, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
Double sided issues
Duplex means 2 sided copying. If you have an odd number of pages, then it will do this if you are sticking them all together (if I understand what you are saying correctly). Either seperate your jobs or stick a blank piece of paper at the end to correct this. Again, I am not sure if I am understanding your situation correctly, but I think that will correct it if its what I think you are saying? Clear as mud, huh?
May 22, 2009 | Ricoh 3310LE Copier
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Printing failed when running big files from computer to copier
try to change the speed of your copier lancard to 10mbps full duplex
Dec 22, 2008 | Konica Minolta DiALTA CF910 Copier
Does PCL6 support duplex printing?
This is gona be a helpful website for you
Jun 27, 2008 | Lexmark T644 Laser Printer
863 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
