Question about Ricoh Aficio CL2000N Laser Printer
Thin lines along left side of Ricoh CL2000N laser printer
I am getting a series of thin lines running along the left side of every printed page on my Ricoh Aficio CL2000N. What part needs to be replaced?
  • gtb1000 Mar 02, 2009
    Thank you!
  • 3 Answers
This is almost certainly the PCU. There are two. One for Black. One for Color. Print a B/W page and see if there are lines. Print a color test page and see if there are lines. This happens a lot to these printers.
To verify, carefully remove the suspect PCU and look at the bottom of it (the shiny roller) Be careful not to spill toner !! You will see the lines on the PCU itself. Replace the bad PCU. If it is the color one, and you are low on toner, you may be better off replacing the printer due to cost.
Posted on Aug 20, 2009
    Scholar:
  • 175 Answers
Like it was already mentioned... 1st if it's just one of the colors then it's probably the pcu for that color. If it's on all colors it's probably either the fuser or maybe some toner spilled on the laser unit. In either case you may have to have a regular tech look at it.
Posted on Jun 28, 2009
Printing B&W? Colour? or both?
Depending on your answer, replace the applicable Photoconductor.
Posted on Mar 02, 2009
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Three small white vertical lines in black printwhere the black does not print. Not present in other colors.
This is coming from the Black Drum Unit. You may be able to remove the unit and look into the slot on the top. You should see the drum which is green in color and may be able to see the lines. Not much you can do with these units so you may just have to replace it.
Jan 16, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N always have to press go for every print
You must have a "special paper" size set in the tray other than "plain", or perhaps the wrong size, so the printer needs you to override the setting. Check the settings. You can find out how on pages 24, 25 of the "operating guide". Go to the following web page to download it -just select your model from the drop down list:
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
Mar 13, 2009 | Ricoh Aficio CL2000N Laser Printer
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Lines priniting on copies
There has a been problems with the PCU. If you contact Ricoh, they can provide you with a new one. If it is under warranty, they can do it at no charge.
Jun 03, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Black lines (streaks) printing on left of page on my ricoh 2000n
Running cardstock lightly misted with water or dilute cleaning solution through several times can help. Use either the feed button or print using a program that allows you to print blank pages.
Dec 08, 2006 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
470 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
