Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote does not work Craftman 1/2 hp door opener
Changed battery, light on back of receiver flashes when remote is depressed. I went up to receiver, held in remote button and held in receiver button at same time until light started flashing (as in the directions on the back of receiver) then let go. Door goes up find with wall mounted button but not either remote. Any ideas.
  • ProfessorJ Mar 03, 2009
    I have the same issue. The door will not operate with the remote. I followed the same procedure found in the Sears owner's manual.
  • lilbigsis767 Mar 06, 2009
    I am also having this same problem with my remote, I also bought 2 more remotes and i can not get them programmed either, I have the craftsman model # 139.53970srt, i followed the instruction both on the unit and that came with the new remotes and nothing works ! ! !
    Sergeant:
  • 227 Answers
Press and release receiver button.
http://www.garagedooropeners.us/helpgifs/maincode.html
Posted on Mar 02, 2009
Craftman 1/3 garage door remote does not open garage
Try another remote to see if it is just the remote or maybe the receiver on the logic board. Check to see if the wall control works and is not in the vacation mode. More information would sure help.
Nov 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
My 20 year old liftmaster model 1040 or 1050 opens on its own. I changed the remote code 3 times and replaced the wall switch. Any ideas? I even went around the neighborhood to see if my remote worked on...
Look at the LED light next to theSMART/LEARN button on rear of the motor unit. You may need to removea light lens cover in order to see it. If the light is flashingrapidly this means you have a stuck button on one of your remotecontrols. Take the batteries out of each remote control. When youremove the batteries from the bad remote, the light will stopflashing. This remote needs to be replaced.
If one of your neighbors remotecontrols is inadvertently programmed into your receiver, you doorwill open when their remote is activated. If this happens you willneed to clear out your receiver and reprogram your remote controls.Press and hold the smart/learn button for 6 seconds or until you seethe small LED light near the button turn itself off. If the abovesteps have been followed and the symptoms continue, there may be anelectronic short in either the wall control button or the receiverlogic board. In this case, remove the wall control wires fromterminals 1 and 2 on the motor unit. Should the symptoms persistafter the wires are removed, replace the receiver logic board. If thesymptoms stop with the wall control wires removed from the motorunit, replace the wall control button, and the wires leading to thewall control button.
Oct 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain remote has stopped working, new
WHEN YOU CHANGE THE BATTERY NO NEED TO REPROGRAM THE REMOTE.
THE FLASHING LIGHT TELLS YOU IT IS SENDING A SIGNAL THAT IS BEING RECIEVED IT IS JUST NOT THE CORRECT CODE TO OPEN THE DOOR.
REPROGRAMING THE REMOTE SHOULD SOLVE THE PROBLEM
HOPE THIS HELPS
Sep 28, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears 1/2 horsepower chain drive garage door opener (circa 1993) would not open with remote and light on back of opener is flashing quickly. Tried reprogramming the remote, but had no success and the green...
It sounds like you have a remote with the button pressed or broken so that it is on all the time. Remove the batteries from your remotes and check that light. The rapid flashing is an indication that it is receiving a signal. Make sure you don't have an old remote in a drawer somewhere.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
332 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
