Question about Admiral AW22 Top Load Washer
Water leaks under machine
Hello, yesterday I moved my machines about 5 feet from where they were, and then water started leaking out from under the washing machine; I had to turn the water off it get it to stop. It is an Admiral designer series (whatever that means) :-)
    Problem Solver:
  • 11 Answers
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Posted on Jun 06, 2009
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Washing machine leaking water from underneath
It is possible it is just a loose hose or it could mean your trmp or the tub itself is leaking. I would try going to the back of the machine and take off the bottom panel.and take off the back panel. After removal start it and observe where the leak is happening.
Jun 14, 2017 | Estate ETW4100SQ Top Load Washer
Leaking water
Your pump is leaking. it is attached to the front of the motor. Very common. Pump retails around $60.
Part number is 3363394
May 19, 2009 | Kenmore Washing Machines
Leaking from bottom of washing machine
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 18, 2009 | Washing Machines
Washer wabbles and leaks
Tilt the machine forward so the rear feet come off the ground, then set it down, this will reset your feet to level. if problem persists, you can lean the washer on its back and inspect the suspension with a light.
Dec 31, 2008 | Kenmore 23822 Top Load Washer
Water leaking underneath when drying,whats the problem
Hello!
If leaks only on drying, then it might be the condensing system, maybe the fittings of the condenser on the drum got loosed. Remove the back panel and inspect after leaks on the left side where the condenser is.
Feb 27, 2018 | Washing Machines
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Saeco Royal Exclusive expresso
hello you say sometime water leak out normally when the water valve seal is defective it will always leak. look under the water tank you got 4 plastic guide moulded in the container make sure no guide broken or missing a little pease of plastic if you got a pease missing add whatever missing inthe hole like a shim check it out cheers
Jan 11, 2008 | Saeco Royal Exclusive 30153 Espresso...
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Admiral AW22 Top Load Washer Logo
271 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
