Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Grease between glass in door after self cleaning mode
I cleaned my 9 month old range using the self clean mode and there is grease and debris between the glass in the door. What's up with that. Is there no seal surrounding the glass?
  • KitchenAid Master
  • 19,396 Answers
As you can see on the diagram below, for the model in title, the door glass is sealed.
Gaskets and sealings are often not covered by regular warranty.
Call the manufacturer at the number listed on your owners manual to check if they can cover the door glass and sealing replacement.
You find all parts and diagrams for model listed in title here.
Posted on Mar 02, 2009
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    No instructions on how to use self cleaning Frigidaire range/oven
    stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
    Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    The inside of my self cleaning smooth top range
    Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
    Sep 07, 2009 | Ovens
    Condensation in oven door glass after steam clean
    No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
    Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Grease in between glass on oven door
    You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
    Feb 22, 2009 | Kenmore 47783 Electric Single Oven
    How do I clean the inside of the door window of my self-cleaning oven?
    umm. there will always be some assemblence of grease on the door glass, if its on the inner most panel and you can scrub it off, then i would reccomned using a razor blade lying flat to scrape it off, however if it has developed within the panel(s) of glass then the only remedy is to dissassmeble the door and glean them that way.. there was some conflict as to the age of your machine in your description, you say "3-hour cycle for the first use late last spring, if I remember correctly--whatever the directions said to do for the first time, a 4-hour cycle after Thanksgiving last fall and a 3-hour cycle for the second cleaning a couple of days ago since it wasn't very dirty"" so i cant be a mont old??? reason i say is that is the unit you purchased probably come with a pretty kickin warr and the manufacture will want ot make good on your issue if you cant resolve it, betterchance though if only 1 month not 11
    Oct 26, 2008 | Electrolux EOG9330 Gas Double Oven
    Dirt and grease between glass in oven door
    i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
    any ideas jimmy
    Aug 01, 2008 | Ovens
    KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
    380 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
