Question about Intertherm P3RC-042K Air Conditioner
Installing hard start
What do i attach the hard start to
i see a comp it has 3 wire to it one said fan , which is brown then there is a red and black do i hook it to the red and black
thanks jim
    Guru:
  • 462 Answers
Id suggest you take this set up back because there are several questions need answering before I can tell you what goes where. also you'll have to go and be femilure with the terminals on the run cap and the compressor also.
In lue of the setup you have,  ASK for a relay capicator hard start ALL N 1. 2 wires and a wire diagram on the kit make it easy to install and its self contained  It tjes up a little less room usually too.
Hope this helps PLEASE GRADE ME ACCORDINGLY and GOOD LUCK.
Posted on Mar 03, 2009
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
I have an arcoaire condenser. dual cap.
Yes, Red to Com, Compressor to Herm, Brown to Fan. You should also have another wire from the condenser fan going to the Com terminal.
Jun 10, 2012 | Heating & Cooling
I have a Ruud Air Conditioner and need to install a new capacitor, but I forgot how the wires were on the old one. Can you help me in tellilng me which wire goes where.
There should be 3 terminals on the capacitor marked "C" "F" and "H".
A wire from the high voltage contactor goes to the "C".
Another wire from "C" goes to the compressor.
These wires are usually red.
The "F" terminal has a wire going to the fan,usually a brown wire.
The "H" has a wire going to the compressor,usually yellow.
There should be a wiring diagram on the control box cover identifying the terminals,colors and number of wires.
Jul 25, 2011 | Heating & Cooling
Just wanting to find which wires go where on switch of fan with light. i have old wire to loop into with new old wire brown / black new black red & green Thanks
I think u mean old cable has 2 wires, those were brown & black, new cable has 3 wires those were black=Neutral, red=Phase go to switch, green=Ground.
Thats it.
Aug 21, 2009 | Monte Carlo 5BY52MW Bayshore Ceiling Fan
How to wire a ceiling fan
What you need to do is take the plate off at the switch on the wall. There shoulld be black wires and white wires. Attach a resistant tester to the white wires, and connect a long wire to the other probe of the tester. then touch the long wire to one of the black wires at the ceiling. If you are lucky, you might get the right black one on the first try. If not, touch the other black one, and that should be the white wire. Have the electric off to test this. When you find which is the white, or common, read the instruction manual and see which of the brown or greenyellow is designated white. I think these colored wires are at the bottom where the lights connect. At the top of the fan should be a white, blue, black and green wire. The Black wire from the ceiling will attach to the hot black and blue for the lights of the fan. The black wire which you discover to be actually white from the switch should be connectied to the white wire of the fan at the top. The red wire sometimes is used to connect to the blue wire so that you have a switch at the wall for the light and one for the fan. That is an old way of wiring fans. Joe
Jun 27, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Wires
2 brown wires go to a split capacitor if you have a dual cap which has three terminals marked comp fan com if u have this type of capacitor then the brown wire goes to fan and the brown and white gets capped with a wire nut. whenever replacing a fan motor you should also replace the cap or at least check the capacitance to see if it is still good. you have to check it with a meter that test microfarad.you can get a permanent split capacitor and mount it in there then u use the brown on one side and the brown and white on the other side it only has 2 terminals.
May 31, 2009 | GE Heating & Cooling
Wires were removed from start cap 3 term need to know which wire goes to which term. terms are not readable
C to cntactor L2/or red side
fan to brown from fan
comp to compressor start term
the one lose wire is far run so goes to C with the red wire
C is the only one with two
May 09, 2009 | Heating & Cooling
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Intertherm P3RC-042K Air Conditioner Logo
140 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
