Question about Roper REX4634KQ Electric Dryer
Roper Dryer model # RED4405Q shutting off
My Roper Dryer model # RED4405Q0 keeps shutting off several times during the drying cycles. I have to turn it back on several times for it to finish drying.
  • Roper Master
  • 8,220 Answers
The motor may be getting hot due to bad rolers idler or glide. You need to take the machine apart and oil it. While you have it broken down you may want to turn the motor and see if it is stiff. The motor can be oiled but it is tricky. there are no oil ports you must make some. I use zoomspout oiler from ace hardware. Its high temp resistant formula and viscosity is perfect for dryers and HVAC needs.
Roper Dryer model # RED4405Q shutting off - 75ddae3.jpgI have various essays on accessing these machines and diagnosis HERE
Posted on Mar 02, 2009
Roper model red4640yq1 heats in auto mode but not on timed dry
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Feb 26, 2016 | Roper Dryers
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
My Roper Dryer stops running during the drying cycle and takes a while to restart.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 22, 2010 | Roper Dryers
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
303 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
