Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer not heating up to dry clothes.
Cleaned vent, trap etc per manual.  what else do I check?  Is it possible the pilot ignitor needs replacing?  Where is the pilot located?
On my dryer the igniter is rt behind the front panel. Take off the dooe and a few screws and pull it off. If the igniter lights at all it is good. Try also checking the entire discharge vent hose as sometimes it gets clogged way dn line and you might not notice it. Try squeezing it all the way dn.
Posted on Mar 02, 2009
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
My dryer runs but no heat.maytag neptune gas dryer.
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Maytag Dryers
Dryer is not heating up to dry the clothes
Good Luck!!
Sep 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MDG850 Gas Dryer: will not get hot
Good Luck!!
Sep 09, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
Clothes have to be dried several times before getting dry
The first thing to do is to remove the ryers exhaust venting tubes and clean them out thoroughly. Any lint build up will cause the moister sensor to keep the heat in check. It is a saftey device to prevent home fires from clothes dryers. Just on small clog will do this. If cleaned and still no heat listen for a clicking noise upon starting. If no click is heard the Spark ignitor is at fault. If it is clicking the moister sensor is at fault
Jun 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat to dry the clothes
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
It does not seem to be heating up. I cleaned the ducts, it spins, it just does not heat up and dry the clothes. Could the pilot light be out?
Your Maytag doesn't use a pilot light instead it uses a electronic ignitor. Since the ducts are all clear and there is power to the unit then the ignitor is most likely the problem.
Depending on how comfortable your are with home repair this is a relatively simple job. However the ignitor itself is rather delicate until it's installed so if you attempt it yourself be handle it with the utmost care
Hope this helps.
Sep 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
556 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
