Question about Philips SA3025/37 Flash MP3 Player
I cannot get my player to charge.
If I hook up my MP3 player to the computer it only says windows does not recognize USB device. znd it will not charge when we hook it to the computer. Also does it have to have some charge to do a reset. thanks
  • 8,596 Answers
If the hold/lock is accidentally engaged, the computer will not recognize the player, and the player will not charge - so check that first.
If it is unlocked, then try another USB port on your computer.
If that still fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
I have the Sony Walkman 8GB Mp3 Player and it's not connecting to my PC so that I can upload music. It is just charging it. My computer won't even recognize that it is hooked into the USB port, but when I...
Check your device manager and verify you have the enhanced host controller installed in the USB device of the computer. If not, consult with the MFR of your computer online and download the driver.
Feb 23, 2011 | Sony Walkman Video MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Feb 16, 2009 | Sony Network Walkman NW-E005 MP3 Player
Barbie girl mp3 player isn't recognized in Windows
remove the backplate, get a pin and push the reset button at the back of the barbiegirl
Sep 10, 2008 | Mattel Barbie Girls MP3 Player
Mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Aug 10, 2008 | Insignia NS-DV2G MP3 Player
Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Jul 08, 2008 | SanDisk Sansa Clip MP3 Player
Computer does not recognize usb device
Dbl click on "my computer" desktop icon and see what you have listed before you hook it up then dbl click again after you hook it up,,,see if there is anything new listed there,,,if so then that should be the MP3 even though it may not say MP3.Mine says Mass Storage.If its there then just double click that drive and you should be able to drag and drop.
Apr 25, 2008 | Coby MPC-848 MP3 Player
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
Philips SA3025/37 Flash MP3 Player Logo
51 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
