Question about GE GSS25LGM Side by Side Refrigerator
Refrigerator side that gets warm and the freezer does not stop r
I have a GSS25WGPD refrigerator
the refrigerator side that gets warm and the freezer does not stop running and has a lot of ice in the back. We opened the back panel and its all frozen
  • 2 more comments
  • ibarra561 Mar 02, 2009
    Thank you so much. I will check that.
  • johnwhagen Mar 04, 2009
    I have a GE GSS22SGMBBS side by side refrigerator with the same symptoms. The refrigerator is at the highest (coldest) setting but is warm. The freezer is also starting to warm near the top (at the icemaker) and the entire back panel has ice crystals on it (i.e. the defrost system has failed). I went to the GE website and the parts diagram shows I have a "Defrost Thermostat" (P/N WR50X10068, $14.50) and a "Heater and Bracket ASM" (P/N WR51X10101, $54.00).
    When you refer to the "Defrost Timer" is this the same as the "Defrost Thermostat"? My "Defrost Thermostat" is electronic and I have a meter to check it. What voltages should I see?
  • ibarra561 Mar 30, 2009
    My refrigerator had the same problems as described by johnwhagen. three weeks ago, I changed a part that goes in the back... the bemetal. It started working fine (of course, because when we replaced the part we defrosted it) and we thought it was fixed but over the weekend it started having problems again: the top part of the freezer was warmer, the bottom was frozen and in the refrigerator top was very warm and bottom cooler but not cold. Anyway...I turned it off yesterday, defrosted it and back on. The freezer is freezing again but the fridge is set to 8 and feels like a 4 or 5. I HEAR the fan in the freezer but not in the fridge...is there supposed to be a fan there? also where exactly is located the timer?
  • sentim May 11, 2010
    I defrost the freezer and open the insideback panel everything all clean and restarted it. It only get cold enough in the bottom, but the coil system got frosted quickly. The fan in the back seems to work well. Please tell me what kind of meter do I need to have or where I can buy it. and where can I find the defrost timer.
    Thank you
    Genius:
  • 1,122 Answers
YOUR DEFROST SYSTEM HAS FAILED,CHECK TO MAKE SURE FREEZER FAN IS WORKING,YOU NEED A METER TO CHECK THE DEFROST HEATER IN FREEZER,YOU NEED TO FIND OUT IF THE DEFROST TIMER IS MANUAL OR ELECTRONIC SO YOU CAN CHECK IT,LET ME KNOW MORE AND I WILL TRY TO HELP YOU MORE-MIKE PS YOU CAN DEFROST IT MANUALY WITH A HAIR DRYER AND IT WILL WORK FOR A COUPLE OF DAYS
Posted on Mar 02, 2009
  • MIKE major Mar 02, 2009
    WOULD HAVE LIKED A FIXYA RATING BUT OH WELL-MIKE
GE seide by side GSS25WGPD
You will need to see if you run the self diagnostics found in the=> Service Manual The problem with the damper could be caused by a defective thermistor, ice build up or just a defective damper. Your model uses the=> WR09X10050 Damper with Thermistor Assembly Running diagnostics wil help you to locate the problem better if you can read and do the from the Service Manual. I am here if you have questions, Sea Breeze
Sep 11, 2013 | Refrigerators
The refrigerator gets warm, stops cooling, and the back wall of the freezer ices up. I replaced the mothWCFer board, thinking it was faulty.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Ice build-up in lower freezer. We replaces the
warm between doors is normal. if hot then clean coils and if coils clean make sure condenser fan motor working thats the fan in the back compartment, however if warm thats good. did the evaporator coil freeze from top to btm is that why u replaced heater. if it was then could be heater,if the coil is only getting frost on half the coil,you could have a sealed system problem. is the evaporator motor working in the frz side if not,then that could be the problem.if coil is froze up it needs to be defrosted. did you defrost coil when you replaced heater,if not try defrosting coils and then wait about 12 hrs and see how it does.
Sep 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Eterna series side by side ice maker doesn't make ice
Hi: . In the warm weather your freezer can warm. I don't mean just frozen. Your freezer has to be at 0 degrees to harvest ice. Ice cream should be rock hard. Set your freezer colder and don't trust cheap thermometers. Also don't do the human thing and check the freezer every 30 minutes to see if ice is made. It will take 24hrs at zero degrees and opening the freezer a lot will not help matters. Hope this helps, Jeff This happens to me every summer. The ice maker will stop or slow.
Jul 05, 2009 | Refrigerators
Freezer way too cold, refrigerator side too warm on side by side.
This can be caused by lots of faults first inspect the evaporator in the back of the freezer for ice build up if this is the case the defrost system has a fault, if not the unit that opens between the wall of the freezer and the fridge may be faulty check for the grills opening and closing
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer fan running non-stop+freezer icing up
very likely that either the defrost timer is not working or the defrost heater is not working.
May 04, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature in both sides are to warm
check the condenser at the bottom part from the front grill. could clogged with dirt. remove the dirt and check the compressor and condenser fan at the back side if they are running. it should be running.
if the compressor is very hot, un plug it for 4 hours and test it again. put the cover back at the back side if you would test it again.
tnx 4 using fixya,
drcool
Oct 20, 2008 | Frigidaire FRS26R4A Side by Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
GE GSS25LGM Side by Side Refrigerator Logo
358 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
