Question about TVonics Televison & Video
Just installed new tvonics250 freeview + box
Just installed new tvonics DTR Z250 freeview + box, installed and worked o.k., set to record, on returning couple of hours later unable to use handset to view epg, menus, recorded programmes,etc. Have unplugged and checked all connections, re-programmed handset, which works t.v.on/off, volume and channel change but nothing else. Can`t get a green light on the set top box, just a constant red light.
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Posted on Jul 05, 2009
Bought a tvonics freeview dtr-hv250 digital tv recorder, keeps coming up but it wont allow me to record. keeps saying the hard drive is unformatted. done what it says on the on screen instructions but
Go to your on screen menu under dtr settings and format the hard drive. If you have been recording the hard drive may be full and some programs need to be deleted to allow more recording space. You may also unplug the unit for several minutes and use the reset box option.
Jul 28, 2016 | TVonics Televison & Video
Where can I find a tvonics DTR-Z250 user manual please
TVonics was taken over by Pulse Eight! I could only find DTR-Z250 manual! Hope this helps! Link below!
http://soapdrama.co.uk/downloads/dtr-hv250/documentation/DTR-HV250_User_Guide_V2_final.pdf
Dec 14, 2014 | TVonics DTRZ250
Failed software download error messages 02 and 10
My version is actually DTR 67500T but I did not realise that you had recorded a different model !! until too late.The shop replaced it with another box
Nov 10, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Hi, I have a DTV Recorder with a WD1600 HDD unit says its not formatted and is unable to format. Tried a new disk, but it wont format that either. Pulled the original disk and I can see two partitions....
Hi, try changing the power supply!
Although mine was showing 12v output (unloaded), once it was put under load there was not enough power to run the freeview and the hard drive at the same time so only the freeview worked. £16 from TVonics and everthing is fine, didn't have to format the drive so I didn't loose any data
Aug 09, 2009 | TVonics STB100 Freeview DTV Receiver
I would like a Sagem DTR 6400T/6700T software upgrade
Pop open remote case you will need knife or thin steel ruler to do this.
Clean the board contacts and the conductive pads with switch cleaner or isopropyl alcolhol cleaner and you will find it will work fine.
Jun 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Mar 05, 2009 | Arris DCT2608
Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Feb 14, 2008 | Televison & Video
Televison & Video Logo
632 people viewed this question
Top TVonics Televison & Video Experts
 Mikey
Mikey
Are you a TVonics Televison and Video Expert? Answer questions, earn points and help others
