Question about Toshiba TEC BSX5 Thermal Label Printer
RIBBON ERRORS WE ARE REPLACING A RIBBON ON THE TEC AND THE PRINTER WILL NOT RECOGNISE THE NEW RIBBON, ALWAYS SHOWING RIBBON ERRORS, TRIED SEVERAL RIBBONS, NONE WORK, TRIED RE-START OF PRINTER, NOT WORKING STILL, ANY IDEAS....
  • pkwc May 11, 2010
    Is the problem appearing with genuine toshiba tec ribbons? What is the exat message? - Ribbon error or ribbon end? Have you in your driver selected thermal transfer and not direct thermal?
  • JDTec
    JDTec May 11, 2010
    There is a sensor underneath toward the back on the left of the bracket where ther ribbon is treaded. In some printers, this moves just enough to cause this error. Just nudge the sensor to the right . Try this let me know.
    Joe
    Champion:
  • 254 Answers
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Posted on Sep 03, 2009
Ribbon error problem for Toshiba TEC B-SX4 Thermal Label Printer
Calibate the detection value and check the rbbon motors values
a sammler ribbon could need some adjustments
Mar 27, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
The Ribbon is sticking to the paper, as the paper is fed. The rewind motor shaft is turning also.
check that you are in thermal transfer mode in the driver.
- Check in the diagnostics mode that the ribn Adj Fwd is not -15
Normally should be zero
Sep 26, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
My tec b452 printer is showing error red light stays on ribbon and labels are loaded correctly
Check that you are not in direct thermal mode and if the roll is correctly placed on the supports. If the roll is not meant for this printer then you have this error
Sep 11, 2010 | Toshiba TEC B-452 Thermal Label Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
System error showing on my toshiba tech sx4
Download a new firmware.
- check that the antiparasite cores are mounted on the ribbon motor cables
Mar 16, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Label prints a tiny amount thenstops and displays ribbon error. Have rebooted the system and the printer (on/off).
Ribbon error: Remove the left side cover, and clean the ribbon motor sensor, located behind the plate that holds motors.
Dec 04, 2009 | Toshiba TEC B-472 Thermal Label Printer
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
Toshiba TEC BSX5 Thermal Label Printer Logo
1,903 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
