Question about Lexmark X7170 All-In-One InkJet Printer
I can't print legal document it won't accept the setting. Now it won't copy but a portion of a page.
  • 173 Answers
Free up your virtual page space or change your port settings.
Posted on Mar 02, 2009
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
HP Office jet plus 8600+ - supposed to print legal but does not!!?!
The printer set up procedure may reveal there is no provision for legal size printing.
May 26, 2017 | HP OfficeJet Pro K8600 Printer
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
Coping Copies of Legal Size
For either a Printer or Copier, the 1st thing is you have to use full-size LEGAL paper. If your copier won't accept this, then you cannot do it. It has to fit in the paper tray.
Second, use the setup menu of your copier and set paper to 8.5 by 14 or LEGAL size, for a Printer
goto Start, Settings, Printers and Networks and find your printer/copier, Right click it, select Properties, select General or Paper tab and look for Advanced Settings. There you will find Paper Size pull down. Change it to Legal, Click Apply, Click Close
Done!
Mar 26, 2009 | Office Equipment & Supplies
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Lexmark X7170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
