Question about Panasonic Heating & Cooling
Unit stops after some hours. Indicating error F41
What is F 41? The unit itself indicate heating pressure switch open cicuit problem. Where is this pressure switch located and why it opens?
  • wim9 Mar 02, 2009
    Panasonic condensing unit indicate on the error F41 on the display after some running hours and stops the unit.
    F 41 indicates heatingt pressure switch open circuit problem.
    Please explain where this switch is located and what has to be done to solve this problem.
  • 398 Answers
Http://www.panasonic.com/consumer_electronics/bp_split_ac/manuals.asp
heres the service manuals just need you serial number
Posted on Mar 02, 2009
MSH123E15AX indoor unit will operate in heating mode. Out door unit MSH123E15MC does operate in heating mode
It could possibly be off on a low refrigerant pressure switch in the outdoor unit indicating a loss of refrigerant. But just in case the unit isn't 'befuddled' a bit by tripping out on a fault of some kind, turn the power off for a few seconds to allow the controller to reset then restart and observe what happens. If nothing happens and you've verified the power as correct, loss of refrigerant is not out of the question.
Dec 18, 2014 | Heating & Cooling
Arcoaire unit. Heat will not come on. Has voltage to control panel from stat for heat. LED is not flashing but staying lit steady. nothing happens at all on heat. AC functions fully and properly.
Look on the units cover plate for a LED code, Determine what code it is indicating and follow the instructions, or post what the code is indicating.
Nov 04, 2013 | Goodman GDS80904BNA Open Flame Heater
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
Jan 15, 2011 | Whirlpool GHW9400 Front Load Washer
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
We've tried to start our Phillips Espresso Bar type HD5702/A, but can't seem to get the water to go into the coffee; Are there a step-by-step instructions on how to get it going (we got it from a friend...
There are merely 3 controls on the unit, two swithes on the right hand side and a turn knob on the left hand side. Press the upper switch - power should go on as indicated by a red light, the orange light of the lower switch indicating the unit is heating up. When the orange goes off, you can press the lower switch whitch starts the compressor to pump up the boiling water into the coffee. During coffee preparation the orange light may go on from time to time indicating the unit is reheating. Stop the pump when coffee is enough. When turning the knob on the left by 90degrees the unit will produce steam and feed it out through the metal nozzle at the left of the unit.
May 30, 2010 | Philips HD-5702
Furnace not kicking on
Kill power to furnace and retry heat. Sometimes high winds will cause a back pressure. That will cause the switch not to work. Also is the fan coming on when it calls for heat. If not check power at the board. You have two wires that go to the draftmotor. They should have 115 volts going to them. But try killing power to unit first. rus Keep in thuch.
Dec 16, 2009 | Goodman GMS90703BXA Heater
E10 code on my kenmore front loading washer
This can mean 1 or 2 things
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
OR it could mean
Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an "E10" will be displayed
  • Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
  • Check Wire Harness connectors to the MCU, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check Motor
Oct 30, 2009 | Kenmore 46462 Front Load Washer
Range with Error Code F5 E0
HI.The Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door)
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Jul 18, 2009 | Kitchen Ranges
Heat does not work when thermostat calls for heat...
This is a safty limit switch. Find two wires that are going to the inducer or combustion blower that terminates to a small disk about the size of a penny. In the middle of those two wires should be a small button. Push firmly down thus reseting the switch. This should do it. It could also be the pressure switch but I have never heard it called that before. If the first doesn't fix the issue. Remove the small tube that runs from the inducer to a black or silver disk, blow out and draw in air until you hear clicking noises. Sometimes they can become stuck. If that doesn't work, remove the other end of the tube from the pressure switch and blow through it. Sometimes debris can clog the entrance to the pressure switch as well. Hopefully this will solve your problem. You can have a bad limit or a bad pressure switch. In this case you will probably have to call someone out.
Apr 08, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
378 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
