Question about Canon PIXMA iP1600 Printer
Waste ink absorber i full my printer i Canon Pixma mp130
  • msolanod Mar 02, 2009
    How can I, reset the waste inkabsorber? Please, explain me, how????
  • Canon Master
  • 19,396 Answers
waste ink absorber i full
my - icon18_wrench_allbkg.png Search Here To Find Service Manual and Resetter Printer
Enter your search terms Submit search form icon18_wrench_allbkg.png Saturday, December 15, 2007 How To Reset Waste Ink Canon Pixma MP130 google_ad_client = "pub-0293684529348718"; google_ad_host = "pub-1599271086004685"; /* 336x280, created 4/10/08 */ google_ad_slot = "1932006471"; google_ad_width = 336; google_ad_height = 280; // window.google_render_ad(); Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
Thanks
Posted on Mar 02, 2009
  • 564 Answers
Unplug your printer. Let me find manual
  • 1 more comment
  • Prem  Kumar
    Prem Kumar Mar 02, 2009
    1. Turn off printer.
    2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
    3. let go button Resume/Cancel, continuing to retain POWER.
    4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
    5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
    6. turn off printer by button POWER.
    It is undertaken from service manual.
    Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
    PREM
  • Prem  Kumar
    STEP 1:
    - Disconnect printer from AC power
    STEP 2:
    - Press and HOLD the POWER button, and
    connect printer to AC power
    This simple power off procedure worked on my IP1500!
    Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
    The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
  • Prem  Kumar
    You can try this link. Will have user guides, service manual and software.
    http://www.usa.canon.com/consumer/contro...
    Thanks
    PREM
  • Canon Master
  • 13,433 Answers
You will need to clean the waste ink container or replace it and then reset the printer, I'll check for instructions
  • Ekse Mar 02, 2009
    after cleaning the waste ink pad(s) which is most cases are in the bottom of the printer, inside not the bottom bottom. but inside the bottom.
    here are instructions on how to reset the printer ones they are cleaned.
    http://printer1.blogspot.com/2007/12/how...
    you can reset it right now without cleaning and it should work just fine but note that since you haven't fixed the problem, you have only taken a painkiller so to say, there will be more problems later.
    canon also offers this as a repair service I'm sure.
    Sergeant:
    Novelist:
  • 277 Answers
You will need to reset the waste inkabsorber to make it proper.
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber full
Hi There you can try
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full How do i empty it
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Sep 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MP130
ink waste absorber is almost full, what should I do?
Jan 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
113 people viewed this question
old marine
old marine
Corne Viljoen
