Question about Acer Aspire 5670 Notebook
Asus laptop freezes when initializing windows after restore discs
The restore disc and driver disc goes through ok but when is freezing when trying to initialize windows. please help
    President:
  • 1,223 Answers
There are 2 problems if ur windows freeze first RAM and then HARDDISK first check by replacinf RAM if it helps otherwise ur hard drive is giving u hard time try replacing it and then install OS from backup disc
i can help u more if u want
pls rate me fixya if ur problem is solved
Posted on Mar 02, 2009
My hp computer keeps freezing while I try to restore it how can I restore it without it freezing?
Hi, my lenovo G570 laptop has a Matshita DVDRAM UJ8B1AS drive, it wont read any disc that is inserted,it starts to spin but nothing else. It doesn't show in My Computer either. Do i need to re- install the driver, if so where do i get it from?
Jul 09, 2013 | Computers & Internet
I have an asus u52f or also known as the u53f with the windows 7 version i caught a virus n did not have the recovery disc after i ordered from asus n loaded the disc once i cam to the utilities n drivers...
Why didn't you just get rid of the virus which is the easy solution? Or you could have done a System Restore to a restore point (date and time) before you caught the virus.
Unfortunately most times those Recovery Discs don't work. The best Recovery Disk that works is the one the manufacturer puts on your hard drive.
Have you checked your hard drive to see if there is a Recovery Partition on it?
See if you can run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 28, 2012 | ASUS U52F-BBL9 Laptop
My asus 1001ha is infected with viruses & wont do anything how do i restore to factory settings?
If it is a bad virus that won't let you do anything on the computer, follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
If you still want to restore it to factory settings, you will need the restoration CD/DVD that came with the laptop, put it in the drive and boot from it to start the restoration to factory settings. If you don't have the restoration disc, you will need a Windows installation disc to install a clean copy of Windows and wipe the HDD. Same process, put disc in and boot from it then follow the instructions for Windows installation (you will need the drivers disc though).
Dec 05, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Arm926ejs laptop freezes on startup
You will have to get your operating system reinstalled most likely. You may have a difficult time getting that done, unless you have the recovery disc for your computer. Your computer came from the factory with Windows CE on it. It's sort of a dumbed-down version of Windows XP. You could try to put Windows XP on it. If you can get it to take Windows XP, then it will probably work better anyway. You may be able to get the Windows CE disc from the laptop manufacturer. Try their website.
Mar 13, 2010 | Computers & Internet
When using the restore discs on my emachine w4682, restore freeze
In that case unfortunately, you are probably going to have to get a Windows DVD. Set the laptop to boot off DVD, and reformat and do a complete reinstall.
Feb 13, 2010 | Computers & Internet
Acer 6930 recovery problem
About the only thing to try is to find another person with the same PC.
Remove the disk-drive from your computer.
Remove the disk-drive from the other computer,
and install your disk-drive.
Run the Restore Disks on that computer,
which will restore to _YOUR_ disk-drive.
When complete, remove the disk-drive, and reinstall it in your computer.
It should boot, and run properly.
Could it be your CD-ROM drive that is intermittently failing?
Nov 18, 2009 | Acer Aspire 6930-6455 Notebook PC
Emachines M5105 wont load discs for system restore
This is probably problem with SATA cable. Try replacing it.
Jan 10, 2009 | Computers & Internet
Emachines M2105 laptop wont reboot from restore discs
Using cd resident OS (Knoppix) check driver for consistency
Jan 04, 2009 | E-Machines M2105 Notebook
Duplicator freezes at 88%, or 98% when burnign and so discs are incomplete
check the amount of free space you have on your computer,if it too low this might be the cause of the problem, plus you might want to run defrag command
Apr 18, 2017 | ASUS Computers & Internet
Acer Aspire 5670 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
