Question about Intel D102GGC2 Motherboard
4gb ram on intal d102ggc2
I want to buy a new ram i have a p4 64bit processor . i want to have 4 gb ram on my system is it possible. else what is a better option
  • 447 Answers
According to these specs your motherboard only supports a maximum of 2gb. The link I've provided should help you determine which ram is best for any upgrade you may end up performing though...
Note: I am not affiliated with the memory vendor linked in this post, it is for illustrative purposes only.
Posted on Mar 02, 2009
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
Pentium 4 with 1.75Ghz available for windows 7?
This should work ok. What version of windows 7 will you using ? Try to have as much as RAM as possible, at least 2GB (not more than 4GB if 32-bit version). Your computer will probably be slower.
see this
http://windows.microsoft.com/en-GB/windows7/products/system-requirements
from Microsoft
14.April.2014
Jul 30, 2012 | Intel Computers & Internet
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
    This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
    Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
    Aug 10, 2011 | Intel D102GGC2 Motherboard
    Wont to upgrade graphic card my p.c has 2gig max ram in it wonts should i upgrade to to preform its best cheers mike
    Depends on what kind of hardware you have
    -Memory- 2 gb ram is "ok" if you use windows XP but if you have Vista or Windows 7 you should have a minimum of 4gb ram.
    -Processor- if you have a Dual core processor you are ok, if you have a p4 or p3 you dont want to waste money on a new graphics card because it will not help you get better games, your processor and memory will slow you down instead.
    So my advice is, if you have a OK computer, go ahead with buying a new graphics card if you computer is old and slow, DONT buy a new card! put your money on +2gb ram instead (cheap,and gives you more benefits) or maybe buy an "upgrade package" with new motherboard-memory-processor.
    May 05, 2011 | Computers & Internet
    Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
    The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
    Mar 28, 2011 | Intel D102GGC2 Motherboard
    I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
    The below is the contents of Intel published for your board
    Intel Desktop Board D102GGC2 Technical Product Specification
    System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
    hope it helps, if so rate the solution
    Nov 16, 2010 | Intel D102GGC2 Motherboard
    Machine randomly restarts after upgrading RAM
    Ok thats the problem.
    1 module with 2gb is not possible on this board:
    http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
    Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
    Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
    You have to use 2 modules with max. 1 gb per module
    Dec 30, 2008 | Intel D102GGC2 Motherboard
    Windows won't see all of my 4GB of RAM but BIOS does! Why?
    Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
    Dec 18, 2008 | Dell PowerEdge 1600SC Server
    Intel D102GGC2 Motherboard Logo
    397 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
