Question about Broan-NuTone QT100L Fan
How do I change the light bulb
I have a fan/light in my bathroom, it is round with a wood circle around the outside, it has 3 switches, one for the fan, one for a dim bulb, and one for more light, the one that doesn't work is the bright bulb. We can't figure out how to get the glass globe down to change the bulb. Do we take the whole wood circle and everything off? Any help would be appreciated....it's like we are starting a joke around here...how many people does it take to change a lightbulb at Granma's house....
Thanks, Paula
  • tbrenna8 May 02, 2009
    Were you able to figure this out? I have tried twisting the glass globe and can see indentations in the globe but when I push up on it and I can't get the globe to budge.
    Thanks.
Hi!
I just figured out how to do this. The wood rim is the key. Pull gently on the wood rim, it should come out of the wall. You will see it is attached by two metal sliding brackets. The entire rim and globe will come out of the ceiling revealing the light. After you change the bulb, gently push the unit back up into the ceiling.
Posted on May 02, 2009
  • 46 Answers
I think that the plastic round will pop out of the center--held in by tabs?
Posted on Mar 02, 2009
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
Three lights and the bathroom fan stoped working on my 79 rockwood
you take the bad light bulbs up . then buy the same model lights .install them on the switch.
ceiling light
May 23, 2012 | Dryers
I have a hunter ceiling fan model 23898 which has a dimmer switch built in one day a light bulb blew out on it and now we cannot turn off the lights with the switch the only way is to loosen the bulbs in...
Has anyone found a solution for this problem? I have tried a bulb in each light socket and attempted to use the pull/dimmer switch that is on the fan itself. The lights no longer dim nor turn off. I have unscrewed all of the bulbs and tried each bulb in each socket one at a time and still nothing. I have also taken the pull switch out of a different hunter fan to put into this one, hoping that atleast the lights would turn on and off. Still the lights won't turn off using the pull switch. I am out of ideas.
Sep 11, 2011 | Hunter Ceiling Fans Individual...
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Dec 22, 2010 | Woods Ind 59008 Digital Timer
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
I hv a bathroom light incorporated in with the ceiling extractor
I would like to help you with this, But with out looking at the light/fan I can't. So what you can do is find the make and model of the Light/ Fan go to there website and email there tech support. # 2 go to Home Depot and ask someone that works in the fan area to help you out.# 3 If you like email me a picture of the fan/ light in four different places, and I'll be able to help you out. j-zubiate@hotmail.com. My name is Jason
Nov 04, 2009 | Dryers
Please could you advise how to change the light bulbs on smeg extractor fan KD70x-1. They seem to be in sealed units, and I cannot get at them from behind when I take the filters out. Thanks!
Had the same problem, eventually figured out that that they just pull down from the outside. You need pretty strong finger nails to start pulling them out at the outer edge of the circle (not the inner circle of teh bulb area, you could use a thin screw driver but then you may scratch your s/teel. Once out look at where the wire goes in and you will see a litle black clip pull this out towards the outside and pull the bulb holder out, you will have to pull the wires initially , then pull out the bulb and replace
Oct 10, 2009 | Kitchen Ranges
Broan-NuTone QT100L Fan Logo
562 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
