Question about Bernina Artista 180
Purchased a new Bernina 830 and need an easy way to thread bobbin
Pictures in manual and on CD go so fast that I can't seem to thread the bobbon case for embrodiery. How do I do it? An easy way would help with pictures.
Pull the thread in the groove of the bobbin case and pull the thread to the left straight and up a bit. I discovered this helps to center the thread in the split where it needs to be.
Hope this helps
Posted on Jan 30, 2011
    Problem Solver:
  • 6 Answers
Load your bobbin in, pull thread all the way to the cutter but don't cut it, see that curved bar in front, glide the thread along that curved bar until you feel a slight click, it should be there, when the 830's first came out they didn't include a mirror, if you never received one, ask your dealer.
Posted on Apr 11, 2009
I have a Bernina 830. Using #03 foot....bobbin thread through the hole in the arm of the bobbin. Why does it not go in reverse to finish the buttonhole?
If it is the older Bernina 830 Record, could be some of the parts have seized due to lack of oil. Frequently, seldom used functions (levers, dials, feed dog control) are the first signs.
Wheel on right side that controls the needle up and down is very tight...
Be sure to move the dials/levers and apply oil there as well.
Dec 07, 2016 | Bernina Sewing Machines
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
I have Bernina 830 embroidery machine. I'm still a novice with this machine. An upper thread broke and could only be removed from the right side. I know that this is a NO NO but I had no choice. I r
Do you have a manual?
You may need some cleaning, oiling or maintenance?
Tips for cleaning and maintenance:
Oil the hook after having used the content of 3 to 4 bobbins. The machine
screen will display a reminder
Increasing noise of the motor and/or irregular
stitch formation can also be an indication that oiling is necessary
Remove any lint from the hook and the bobbin area, then remove the stitch plate
See instruction manual chapter Maintenance/Cleaning
YouTube videos: Bernina 830 or 880 Thread Nesting Troubleshooting
Feb 08, 2015 | Bernina Sewing Machines
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
I am loading bobbin and can't thread cotton
Open the manual and lay it right next to the machine.
Raise the presser foot and thread the machine - always have the presser foot up for this proceedure - according to the written instructions. Same for the bobbin.
The tension should be set according to the recommendations in the manual.
Once you get the machine set-up and sewing.
Refer back to the manual as you read and test each and every feature of the machine.
This will help you become better acquainted with this particular model.
It matters not how new you are to sewing or if you started sewing when Eve needed to switch from fig leaves to textiles - everyone needs to read and apply the instructions provided in the manual. Graphics and pictures are helpful but sometimes miss important steps.
Best wishes for many successful projects.
Mar 14, 2010 | Bernina Sewing Machines
Old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Aug 29, 2009 | Bernina Sewing Machines
Bernina 1630 Thread works fine then goes in revese for a couple of stitches and then back to normal. Bobbin thread loose.
sounds like ur bobbin needs to be tighten, when loose the bobbon does not stop and you get more thred then needed hope this helps... Velz...
Jul 18, 2009 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
315 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
