Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Dryer stopped in the middle of the cycle - won't restart
I put boots in the dryer on low with a few beach towels and one of the boots got wedged in between the top of the dryer and the rotating drum. It was literally hanging from the top! My question is - is there a sensor that shut the dryer off before real damage could be done to the motor or did I do major damage?
How do I even begin to troubleshoot this?
  • steve
    steve May 11, 2010
    Did you say BOOTS?
  • 25 Answers
Check drive belt and purchase a boot dryer.
Posted on Mar 08, 2009
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire FGQ332ES Gas Dryer
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Electric dryer stopped in the middle of a cycle of towels (or after they were dry...not sure, as renters reported problem). . There appears to be no current..panel does not light at all Have reset the...
My 4 yr. old Maytag electric dryer stopped in the middle of drying towels and wouldn't restart. I called one repairman who told me it was my motor and I called another repairman closer to where I live and he came out and replaced my fuse. My dryer works fine now.
Aug 17, 2011 | Kenmore 63942 Dryer
Started the dryer , but forgot to add few clothes so stopped the dryer in the middle of the cycle and restarted it, but it never started, even the switch button is not getting pushed in
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Magic Chef CYE3005AYW Electric Dryer
Gas dryer 12690. When stopping dryer in the
When the dryer stops and you try to restart it do you hear a buzzing sound? If you do then you have a overheated drum motor. Full of lint or bad motor bearings. If bad motor bearings only solution is to replace the motor.
Mar 29, 2010 | Kenmore Dryers
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
