You need to change out the burner orifice, change the filter and make sure there is pkenty of oil. Bleed lines at brake like valve until there are no bubbles present.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
I have a Honeywell Chronotherm III thermostat. Occasionally I will hear it come on, the gas...
(More)
I have a Honeywell Chronotherm III thermostat. Occasionally I will hear it come on, the gas burner/blower kicks on but the blower fan for the house will not start. When this happens, the thermostat displays the current time and -A/C. I tried moving the fan switch to ON instead of AUTO but the fan does not come on. Eventually it comes on but I can smell the "hot" smell in the house because the burner continues to run without the blower fan going.
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem...
(More)
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem exists- Thanks, Richard
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on...
(More)
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on "Leave" at 58 degrees at 7am and "Return" at 66 degrees at 4pm. The unit starts heating the house at 12noon to move it 8 degrees. According to the directions it should only kick on a max of 24 minutes per degree not 4 hours - any suggestions?
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and...
(More)
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and humidity. what could be wrong?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
