Question about GE Profile JP930 Electric Cooktop
Burned Copper Bottom Pot on Glass Stove Top. This left a ''melted'' portion of the pot on the glass. Any ideas on how to remove the melted residue?
  • beezzlee Mar 03, 2009
    Thanks Bob, at least now I can stop trying. I did look at the manual, and oddly Copper Bottom pots are recommended, however it does state that the copper can 'melt' if you let the pot get to hot. Thanks again for your answer.
    President:
  • 267 Answers
Sorry to say no , if you try to peal it off or scrape ot off you will crack the cooktop . this keeps happening i have seen it at around 4 times for some reason revere ware melts . there should be a warning in the manual ( i know ge does have the warning about copper bottoms ) . replaceing the cooktop or the whole stove is the only "true" answer .... sorry .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
Pot stuck to cooktop
Did you find that it was stuck after it had cooled off? A vacuum was probably created between the pot and the glass top. You could try twisting the pot, leaving it for a while, or heating it up again.
Apr 11, 2010 | GE Profile JP930 Electric Cooktop
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Whrlpool Electric Stove Top Burners
this is a ceramic top i am guessing.
this is normal, it isthe way it is designed.
it does this so that it does not cause a heat fracture to the glass.. it will continue to turn on and off.. but if you put a pot of cold water on it you will find that this will happen alot less frequently.
Oct 09, 2009 | Cooktops
Repair large chips to white enamel on stove top.
Get some glass enamel powder the same colour of course...I got it off ebay.or go here.www.find-a-fix.com/
Aug 29, 2009 | Cooktops
Puiter stain on stove top
ITS NORMAL FOR GLASS CERAMIC, NO KIND OF CHEMICAL TO CLEAN.
TNX GERBEE
May 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
GE Profile JP930 Electric Cooktop Logo
1,589 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
