Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
How do you remove the drain hose on a Bosch Dishwasher SHU3307?I I have the door off.
  • 27 Answers
You need to take the left side panel off and in the back of the base you will see the drain hose connection into the water intlet assembly. disconnect it from there then the hose will come out.
Posted on Mar 19, 2009
My Bosch dishwasher Model #SHX4APO5UC/06 wont finish the cycle and it wont drain. We have checked hoses and they are not clogged. Is it something with the control panel?
Check your motherboard for burnt contacts. Easy to remove in the door. If you able resolder and give it a try. Cheaper then a new mother board.
Aug 11, 2014 | Bosch Dishwashers
How do I change the waste hose on a Bosch Dishwasher Model Number SMS53E12GB the existing hose has been crushed by the base of the machine. I cannot see how I can get to the connection point at the base of...
It is not the easiest thing to do,here is what you have to do;
turn off power supply and water to the dishwasher
remove screws mounting d/w to counter top
remove lower panel
disconnect water and power from d/w
lower legs
pull out from under counter
remove panels covering door hinges
remove linkage from door spring to door hinge
remove the Torx screw securing tub to base frame in the front&rear
pull on base frame to seperate tub from frame about 8-10 inches
remove drain hose from drain pump/install new hose
reassamble in reverse order
Good luck,
Gene
Aug 06, 2011 | Bosch Dishwashers
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher not draining
Hi
"Dishwasher not draining" issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Jul 22, 2010 | Bosch Dishwashers
Water wont drain, I have removed drain hose from back of machine run cycle and still nothing more than a trickle. I am guessing its plugged but im not sure of the best way to test or clear the plug. its a...
im a old bosch tech and your problemis in the drain pump. remove 1 screw in the bottom of the unit and you will take off the plastic door, spin propeller and remove obstruction that will do it. if this helps send me a 4 thumbs up post thanks
Feb 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Replacing drain hose
you have to pull dishwasher out all the way. if you have side panels open door and on left side youll see 3 screws, all torx head, remove screws to get side panel off. once you have the panel off youll see how to pull out drain hose
Nov 14, 2007 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Front panel
Did you knock out the plug on the disposal before you hooked up the drain hose ?
Aug 19, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
144 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
