Question about Maytag PYE2300AY Electric Dryer
Maytag pye2300ayw dryer burnt rubber smell
Maytag pye2300ayw dryer after a few minutes burnt rubber smell. belt is not broken. drum seems hard to turn. only 4 years old. belt broke 2 years ago. replaced belt.
  • midwestmike Mar 02, 2009
    Maytag pye330AYW, also experiencing burning smell after the dryer runs and it also tripped the circuit breaker. Running on air fluff produces no odor.
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
  • 2692 Answers
SOURCE: I have a kenmore series
Remove back of drier after disconnecting the power cord. Find old belt laying on floor under machine. Obtain new belt and place around drum and motor pulley. done
Posted on Dec 26, 2008
  • 686 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Posted on Feb 27, 2009
ned_san_jose
  • 234 Answers
SOURCE: Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Posted on Jul 07, 2009
nnesmith
  • 162 Answers
SOURCE: How do I replace the dryer belt on a maytag dryer
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Posted on Jan 30, 2010
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
Belt installation is too loose on Maytag dryer model # pye2300ayw? Trying to fix it need a diagram??
Hi and welcome to FixYa, I am Kelly.
If the belt is loose it is most likely stretched / worn and should be replaced:
The idler (item5) of this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=630165#d630165
See routing here: http://www.repair-help.com/kb/index.php?article=105
The drive belt is item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560
The top must be opened and the front panel removed to install the belt.
Here is a link to step by step "how to" instructions.
http://www.ehow.co.uk/how_7277908_do-belt-maytag-pye2300ayw-dryer_.html
Make sure to inspect the rear drum rollers while you have the dryer open. Item 7 this link:
Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Additionally if the front or rear drum seals are worn it can cause the belt to be loose. These are glued on with high temp adhesive.
The front seal is item 10 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505910#d28505910
The rear seal is item 2 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505913#d28505913
High temp adhesive: http://www.appliancepartspros.com/part_details.aspx?part_id=4284239
By replacing the items above your dryer will operate like new again and extend the life of your dryer by many years.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Maytag Dryers
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
DRYER RUNS TEMPERARILY WITH WHINNING NOISE THEN SHUTS OFF.
take off front of the dryer the drum will fall out clean drum and replace belt
Feb 10, 2009 | Whirlpool LER5636P Electric Dryer
PYE2300AYW Dryer how do you remove the drum?
Once you loosen the screws from the spindle or axle, you should be able to pull(gently) the drum out. Be careful not to damage the rubber wheels. My question is why do you need to pull the drum anyway? It has nothing mechanical or electrical to it. Are you wanting to put a belt on?
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
291 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
