Question about Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
FT-11R with no RF Out signal
My FT-11R does not transmit anymore, no RF as also no red TX Led when
pressing the PTT button.By interchanging boards with a good FT-11R, I
found out, that the RF unit is not working.
My local dealer has no repairing parts anymore so does Yaesu.
Can anyone help me on this? Does anyone know where to get a repair manual with schematics partslist and layout to repair it myself.
vrc_tech
  • 109 Answers
SOURCE: Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Posted on Aug 21, 2008
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
mohammed387
  • 1952 Answers
SOURCE: manual yaesu ft-10r
www.radioamateur.eu/schemi/FT10_40_user.pdf
Posted on Jun 29, 2009
SOURCE: Yaesu FT-26
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
Posted on Jul 27, 2009
  • 4 Answers
SOURCE: Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Posted on Mar 17, 2010
TRC 521, PTT button depressed, TX Led intermittantly Off. Press PTT several times TX led than works. Whats going on?
try some electrical component spray on the inside of the mic.Just a dash of it should do. not making good contact.
Mar 28, 2012 | Radio Shack TRC-521 CB Radio
I CAN HEAR THE DISPATCH BUT THEY CAN'T HEAR ME. WHAT IS IT ? IS IT A MIC,? PLEASE.....HELP. I HAVE A RADIUS SP50 MODEL.
First, make sure the battery is fully charged and red LED TX indicator is on steady as long as you are holding the PTT button. If the red LED blinks while you are transmitting, the battery is not charged, or is bad.
Otherwise here are some common problems with the SP50 that can cause that issue:
Bad PTT switch
Internal microphone is bad
Speaker/microphone is bad-if used
Jacks are bad
Transmitter power amplifier is bad
Antenna is bad
Contact a local dealer for proper diagnosis.
Feb 09, 2011 | Motorola For SP50 7.5v 1500mAh NiCd...
My cobra 200gtl has no transmit
hi More than likely your pa transistor has blown have you checked it with a power meter if so r you getting the red tx led when the ptt is pressed if so then your problem lies with the rf transistor
replacing rf transistor
Jan 18, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
Yaesu FT-416 not Transmitting
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Feb 24, 2009 | Vertex FNB-27SM,...
TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Jan 25, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
COBRA 29 LTD
Your concern is no transmit and no red transmit led -
If there is no receive likewise, then probably problem in the PLL/VCO section or 9V voltage regulator TR23 (2SC1096) or Zener diode D22 (9.1V).
If the receive is normal, then possibly any of two (2) faults:
1. microphone/PTT switch and/or the mic cable specifically the wire connected to pin# 3 of the connector; or
2. +8V switching transistor TR21 (2SA733P).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 30, 2008 | Cobra 29 LTD CB Radio
Kenwood ts-450s - cannot tune and no ptt
This is usually due to a stuck or shorted ptt line. I have repaired a couple of these and it was the same component each time. The packet TX transistor Q65 shorted causing the radio to power up in TX inhibit mode. Transistor Q65 is located on the underside of the IF board under the ACC 2 connector. This switching transistor is used only for tx (pin 9 of acc 2) and no other circuits depend on it. It can be removed completely if you don't mind not having ptt on acc 2.
This seems to be a common problem lately, I hope this helps you.
Apr 26, 2008 | Radio Communications
Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio Logo
160 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
